Safe to use 2 jack stands instead of 4?
Chock the wheels. Once you get it in the air, grab a lifted wheel with both hands and try to shake the car hard. Don't be under it, and don't be timid. See if it will come off the stands. Fixing a floor is cheaper than fixing a lung, or being crushed to death.
^Thats what I do. Grab the car and shake like hell with my whole body. (When I'm doing major stuff...like pulling transmissions, changing exhaust since those require lots of power- snapped lots of exhaust bolts so far...)
I use the floor jack to lightly support any point on the /mid/rear after the front is on two stands. Probably ain't necessary but I do feel much better about it and you might as well put your jack to some use as a possible safty "net".
California residents need to be aware of a possible earth quake so maybe as much support as you can get. This is the only scenerio I can imagine that might shake the car off of stands.
Always chock the wheels to help prevent the car from rolling off the stands. Stuff any wheels that come off the car back under the car as extra insurance.
Always remember to -un-chock the wheels when you are done or when you're backing out you might roll over one and send it flying into the wall of your garage...
I almost did the same when I flushed the CMC.
Originally Posted by starchland,Nov 29 2009, 12:54 AM
you can just drive up on the pieces of flat wood on one side if you dont want to jack the car up. also put a tire under neith the car if your using jack stands just as a precautionary measure.
