Secondary o2 sensor
Old Jun 7, 2013 | 11:32 AM
cinaibur's Avatar
Former Sponsor
Default Secondary o2 sensor
So I was throwing P0137 and P0138 codes the other day. Asked the dealer for a price for the o2 sensor, and it was outrageous. Also, they didn't have it in stock and couldn't get it for several days. Autozone, NAPA, Advanced, and OReily didn't have one and they were all in the $180-230 price range. I decided to look it up on RockAuto and found an NTK o2 sensor for $64!!! Not only that, but it said they were the OEM manufacturer. It showed up yesterday and it is absolutely identical to the OEM sensor on my 07. Here is the kicked, notice that the tip is completely gone from OEM sensor when I pulled it. I've never seen that happen. Glad it was the downstream sensor.
Old Jun 7, 2013 | 12:34 PM
gen2gsr's Avatar
Items OrderedPrice1 of: Bosch 15733 Oxygen Sensor, Universal Type Fitment
Condition: Used - Like New
Sold by: Warehouse Deals, Inc (seller profile)
$10.21
This fixed my ap1, code p0141. Amazon open box return FTW. Also, the tip breaks generally because the core of the catalyst has dislodged and now rattles around. This is my second sensor in 12 months.
Old Jun 7, 2013 | 12:42 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
cinaibur, be sure you use a spark plug spacer on your new o2 sensor, or it will be broken in no time.
The reason the tip broke off yours is because the cat media is broken loose inside the cat.
The spacer will protect the new o2.
Old Jun 7, 2013 | 02:23 PM
s2000maniac's Avatar
you might be losing some power since the broken honeycomb could be restricting air flow.
kikkomon
Nov 29, 2015 07:59 AM
black2000
Apr 26, 2010 03:05 AM
