Seized Alignment Bolts
As the subject line indicates, my rear alignment bolts are stuck.
My plan is (if copious amounts of anit-seize fail) to snap off the head and hammer the s**t out of it to get the damn thing out of the bush. If the metal collar goes with it, then so be it, I can remove that without causing any damage.
I spent an hour or so flicking through the FAQs/threads etc, no one seems to have this approach.
Has anyone tried this? Or is this really not advised?
Whenever I tackle a siezed bolt, I used lots of liquid penetrant. If that fails, try using a propane torch to get the bolt and stud red hot. (Just make sure that there's no rubber in the vicinity that might melt.)
