Sensor thats connected to the air box!
Old Aug 4, 2009 | 02:49 PM
s2k dre's Avatar
Default Sensor thats connected to the air box!
Does anybody know if u can eliminate that sensor? It has 1 connector goin to it and it has 2 vaccum lines that run right under the fuel rail.
Old Aug 5, 2009 | 06:19 PM
s2k dre's Avatar
come on, somebody has to know.
Old Aug 5, 2009 | 08:33 PM
MasterForce's Avatar
pics??
Old Aug 5, 2009 | 08:54 PM
s2k dre's Avatar
Look at the 3rd pic in the link. The sensor thats sitting on the cross member.
https://www.s2ki.com/forums/index.php?showtopic=171067
Old Aug 5, 2009 | 10:51 PM
J0eys2k's Avatar
Thats the air sensor if I'm correct. I think I ask my tech professor once about it and he stated that removing it will mess with the flow of oxygen to the throttle. Its been 3 years so I could be wrong
Old Aug 5, 2009 | 11:38 PM
AusS2000's Avatar
It's the solenoid that controls the secondary air injection system. If you still have the OEM ecu you still need it. If not, you don't.
Old Aug 6, 2009 | 11:04 AM
F22PwrdS2K's Avatar
Old Aug 6, 2009 | 11:16 AM
s2k dre's Avatar
Even if u delete the vaccum lines and just keep the connector?
Old Aug 6, 2009 | 02:44 PM
AusS2000's Avatar
If you still have the OEM ecu you still need it AND THE VACUUM LINES. If not, you don't.
Old Aug 6, 2009 | 04:08 PM
Ness2000's Avatar
I use a piggy back (EMU) and removed all the lines, and there's no issues. The pump runs as normal, but doesn't blow air anywhere except right out the pump. No CEL or anything.
