Sheared off axle from hub HELP
Old Feb 27, 2013 | 01:27 AM
Topplayer's Avatar
Default Sheared off axle from hub HELP
axle sheared off on sunday doing a second gear pull. after the pull it started clicking, and I heard a fiction rotational noise. drove around for 5 mins in a parking lot to see what it was than I went into reverse and it was over. here are some pics Trying to figure out where to start. any help would be very appreciated
After taking the wheel off I noticed uneven pad ware
Old Feb 27, 2013 | 02:04 AM
miloking's Avatar
Should be easy, take of the large 36mm nut, hammer that broken piece of sucker out and get new CV joint (or likely whole axle, BTW i think they are different lenght left to right).
Oh and clean/grease up your caliper sliding pins (and maybe the piston too) and get some new pads
Old Feb 27, 2013 | 02:53 AM
riceball777's Avatar
that use to happen to me a lot with my integra's stock axle when I was turbocharged. Are u boosted?
Old Feb 27, 2013 | 02:55 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
1 unbolt abs sensor
2 pop lower ball joint
3 remove axle
4 call Billman to deliver an axle
Im heading your way Thursday morning looks like passenger side.
Old Feb 27, 2013 | 02:58 AM
Topplayer's Avatar
been trying to get a hold of you for awhile LOL gonna call you today for sure!
Old Feb 27, 2013 | 03:03 AM
Topplayer's Avatar
supercharger, pulled way to hard in 2nd gear.
Old Feb 27, 2013 | 08:28 AM
SouthDakotaS2K's Avatar
That could have happened after the axle broke. The axle actually holds the roller bearings together.
Old Feb 27, 2013 | 09:32 AM
Topplayer's Avatar
new axle is on the way, should have it all fixed up for the weekend than ill drive around and see. the pads are basically new with new rotors
Old Feb 27, 2013 | 10:22 AM
MM3Kwolik's Avatar
DAYYUMMM, that sucks! Glad you're getting taken care of though. Luckily it looks like it's just a new axle and you'll be good to go. Hopefully when it gave out it didn't do anything to mess up your diff. Good luck!
Old Feb 27, 2013 | 02:23 PM
Kmelthratter's Avatar
Sometimes Mid-engine cars stick toooo good. Ha ha
