Shifting into 6th is weird.
Old Aug 21, 2006 | 01:29 PM
jphish's Avatar
Default Shifting into 6th is weird.
I was driving hard through 3rd. I shifted at redline in first, second, and third and slowed down and shifted into 4th, 5th, and then I tried to shift into 6th but it wouldn't go. I downshifted to 5th, then 4th, and back to 5th then 6th. It finally went into sixth with a little more pressure than usual. The car drives normally in 6th once in gear. With the car stopped, I shift 1st-5th just fine but 6th sounds and feels like it is scraping. Anyone seen this before? Thanks.
Old Aug 21, 2006 | 01:31 PM
kenny_son's Avatar
i get a kind of notchy feel too...like its kind of scraping the gate or something....rarely do i get a smooth 5 to 6 shift.
Old Aug 22, 2006 | 07:59 AM
s98d7fs's Avatar
My 5th and 6th are sometimes notchy when cold. Once the car warms up they are smooth as silk. Could be the synchros are a little worn (even though mine's an '03 with 47kmiles on it). In any event, I now try to warm the transmission up before I start shifting into 5th and 6th.
Old Aug 22, 2006 | 08:57 AM
cmflex84's Avatar
I get the same thing in MY00. Sometimes 1st-2nd and 2nd-3rd is rough but 5th-6th always feels weird. Its not a grind but its not a smooth transition either. Worn synchros is my guess
Old Aug 22, 2006 | 11:05 AM
SpitfireS's Avatar
Do any of you "skip-up-shift"?
IOW 1st - 2nd - 3rd - (then you are going fast enough) - 6th?
If so, that is most likely your problem => stop doing it.
(but the "damage" is done)
Change transmission oil more frequently.
Search the OIL JOURNALS for another transmission oil.
Old Aug 22, 2006 | 11:58 AM
jphish's Avatar
What "damage" are you talking about?
Old Aug 22, 2006 | 12:28 PM
SpitfireS's Avatar
jesusphish Posted on Aug 22 2006, 09:58 PM
Synchro wear.
When you shift from 3rd to 6th, the 6th gear synchro has to do a lot more work.
Slowing down the mainshaft to the engine revs that "belongs" to 6th gear at that road speed.
(read it more then once... )
More work then it was designed to do => 5th to 6th.
If you go through all the gears that slowing down is devided into smaller steps.
"skip-up-shifting" wears out synchro's.
There are many MANY posts about it here.
Old Aug 22, 2006 | 12:35 PM
Zeemz's Avatar
I have to double clutch to get 6th to engage smoothly when the Tranny is cold. Once it warms up its smooth as butter.....
Old Aug 22, 2006 | 12:48 PM
jphish's Avatar
Thanks. I appreciate all the good advice. I will definately heed it in the future. Taking it in to the dealership to have them look at it.
Old Aug 22, 2006 | 02:18 PM
s98d7fs's Avatar
No skip shifting in my car. I've had it since 33kmiles and its currently got 47kmiles. I've tried replacing the MTF with Honda OEM and I have Specialty Formulations MTL-P in the transmission now and I like how it feels. It could be that I've changed my driving style and it makes me notice the feeling more. I got the car last December and it was my first manual.
The 5th/6th feeling has come in the past 3kmiles and I've just decided to play nice-nice with it and hopefully I'll smooth out the synchros. I will say that it has got better than it was when I noticed it originally.
