shifting issues
Old Jan 27, 2010 | 05:45 PM
hypforlife32's Avatar
Default shifting issues
when i go to rev match into 4th 3rd or 2nd gear, sometimes if i let it ride down under 3k rpms and push in the clutch the clutch will not dis engage and i will have to push it out of gear or try and push the clutch in again to take it ouf of gear. any idea would be much appreciated
Old Jan 27, 2010 | 06:07 PM
dales2000's Avatar
check your clutch fluid might want to try bleeding it
Old Jan 27, 2010 | 06:10 PM
yeah my clutch fluid is kinda of dark and grey...could that be the issue?
Old Jan 27, 2010 | 06:17 PM
dales2000's Avatar
i would bleed it and see if that helps, also check inside your car for leakage from the clutch pedal.
when bleeding make sure the the fluid does not get too low so air doesnt get into the system, might want to get a friend to help
Old Jan 27, 2010 | 09:21 PM
CapoArgentino's Avatar
Banned
If the clutch is not disengaging properly even if you floor the clutch pedal, sounds like the pressure plate might be on its way out, unless you are leaking clutch fluid (Keep reading). How many miles does your clutch have now? Is it also hard to do normal shifts?
Clutch fluid shouldn't be an issue if its at the full mark. If it is at the full mark, that is also a strong indication that the slave and master cylinders are not leaking (Being the slave cylinder the one that usually starts to leak first). Also, clutch fluid will last 100K+ miles easy.
Old Jan 28, 2010 | 06:17 AM
i havae 55k on the normal clutch. normal shifts are to hard but they are like easy. like from 1 to 10 i would say a 3 on the hardness
Old Jan 28, 2010 | 09:28 AM
Banned
My OEM clutch parts started acting up at about 65K miles. I left it as is until I could not shift at all unless I double clutched
So here's the deal, check your clutch fluid. If its full, time to replace the clutch disc and pressure plate
Here's what I have and recommend:
* ACT Heavy Duty pressure plate and street disc (Comes as a kit that also includes the throw out bearing and clutch alignment tool).
* If you have some extra cash, I STRONGLY recommend you replace the flywheel too since you will have the gearbox out anyway. Im using a Fidanza 7lb flywheel.
Old Jan 28, 2010 | 10:00 AM
yeah if i do the clutch and everything its def getting a lioghtweight flywheel.
is this the clutch kit you are talking about here.
http://www.advancedclutch.com/products/clu...od_id=5799#5799
the first one with the street disc? i am planning go turbo anyways. im hoping for around 500whp so would this clutch setup hold?
http://www.vividracing.com/catalog/fidanza...02-p-10210.html
also this flywheel?
Old Jan 28, 2010 | 10:05 AM
Banned
In that case, this is what I recommend: HS1-HDG6
This is a 6-puck disc but without the harsh engagement of a 4-puck. This will hold your FI setup fine and at the same time be easy to use on the street.
Old Jan 28, 2010 | 10:07 AM
o okay. thanks for the help. now can i still run an 8lb flywheel with this setup?
