Does anyone have the single outlet Veilside teardrop? Also, is there any way to remove the plastic beneath the back bumper? Single outlets look so dumb with that other half circle cut out on the other side. Anyone have any singles this way?
I think if someone (sponsor?) built a modified black rear fascia (I couldn't imagine it'd cost much) they would probably sell one to every owner who's bought a single exhaust. I know many won't buy a single for that reason alone.
I have the Veilside on mine, but the extra cut out on the rear doesn't bother me much. I actually spoke to a friend of mine that works with cf about making a piece to fit into the spot, but the idea never got off the ground.
We all tend to think a single exhaust will look bad, but in practice, you tend to get used to it very quickly. At least I did.
The rear bumper is all molded as one (black section and body colored section), so you can't remove the lower portion without hacking things up. I have a bad feeling any "insert" piece for the blank hole will look contrived and only worsen the situation.
In any case, wait till you've got a single exhaust and you're totally sure you're unhappy with how it looks before fretting over it. I'm willing to bet you won't end up caring.
