A slew of problems
Old Jan 19, 2014 | 10:10 AM
gnows2k's Avatar
Default A slew of problems
Sup guys, have a few problems with the S unfortunately.
1st thing I have a oil leak, and narrowed it down to the vtec solonoid gasket, so I'll have to replace that.
But now I'm noticing ever so slightly decreasing coolant in the external reservoir. To add to that, whitish smoke emits from my exhaust, albeit not all the time but occasionally. could it be head gasket?
Also I checked my spark plugs too, as I read somewhere that could indicate coolant leak.
I only managed to take a pic of the front most spark plug before it started to rain
1st
2nd
3rd
4th
Old Jan 19, 2014 | 02:07 PM
slalom44's Avatar
Top Answer: 1
If you have white smoke especially at startup and you're losing coolant, you likely have a leaking head gasket. Other symptoms include:
  • Black greasy residue in your coolant reservoir
  • Fluid level in radiator going down (checked when cold), but not in the reservoir
  • Engine overheating, running hot
  • engine sputtering at startup
I don't have a lot of experience at reading spark plugs, but if you look at all four and one is noticeably different, that is likely where you have your problem. The spark plug photos you posted don't appear to be bad to me.
Old Jan 19, 2014 | 02:33 PM
gnows2k's Avatar
Thanks for the response, as for radiator level going down, that's the only sign, in pics 1 and 2 though those spark plugs have the most bluish color to them than 3 and 4
UH-60DRIVER
Nov 12, 2016 08:26 AM
-Matt
Nov 16, 2015 06:37 PM
PRDeliz
Mar 28, 2012 07:30 PM
durtbikedude365
Nov 25, 2010 09:01 AM
mikerino
Aug 30, 2007 03:06 AM
