Slipping Clutch
My clutch is slipping and I'm wondering if a specific part is to blame (maybe the clutch/friction disc) so that I can just replace/repair that part? I don't really want to pay $1000 for an aftermarket setup right now.
Originally Posted by s2krazy01,Jun 14 2006, 11:51 PM
42.5k miles and it will slip if I floor it in any gear.
Clutch disks usually last me 100,000 miles or more, but both driving conditions and driving style can shorten (or lengthen) clutch life.
Replacing the disk is not going to be cheap, so if you're ever going to upgrade the clutch, this is the time to do it.
) the pressure plate if it has burn marks on it and definately resurface the flywheel.You could go the cheap route and just replace the clutch disk, but it will suck when your clutch goes out again within 15-30k miles.
when it comes to upgrade a clutch, how do we know which kind to get, stage and brand wise, etc? Stage 1, 2, 3? Also, what are pros & cons of using a stainless steel clutch line? Are they used with stock or upgraded clutch kits? How are these supposed to affect the clutch pedal? Are these worth getting?
It is the friction disk that is not holding. Since labor is the biggest part of clutch work most replace all parts. You can simply sand (regular 100 grit sandpaper) the FW and the PP to avoid replacing them most of the time for some savings.
Basically I think you've got two choices; You can take the advice of the people here on S2kI or elsewhere, or you can talk to the manufacturers and decide for yourself what kind of setup will best suit your goals and needs.
Unless you're having corrosion issues I can't see much benefit from stainless steel lines, but they do look cool.
