Snapped screw
Old Oct 16, 2006 | 07:10 AM
Jql168's Avatar
Default Snapped screw
I noticed that my damper screw had snapped in the hood, so pretty much half of the threads is stuck in the hood, any idea how i would go about getting it out? Any help would be great
Old Oct 16, 2006 | 01:02 PM
SpitfireS's Avatar
A picture would be nice
To show what exactly is the situation.
Old Oct 16, 2006 | 03:15 PM
RadioZero's Avatar
lets assume your talking about aftermarket hood struts. sounds like it's time for some "easy out" screw removers. check with Harbor Freight or Sears.
Old Oct 16, 2006 | 03:28 PM
Boofster's Avatar
Ahh...had this same thing happen to me on install.
They had a specialty drill bit at ACE hardware that looks like a long cone but is reverse threaded. So you take a regular drill bit, drill the bolt just a little, preferrably with a dremel (be very careful), and then just keep threading the special bit as if you're undoing the bolt.
I forget what the exact name for it was but they had it in the locked cabinet and it came in a few sizes. I think I went with the smallest one. You also need the correct size regular drill bit to go with it.
Old Oct 16, 2006 | 06:44 PM
Jql168's Avatar
Thanks for all the help guys, i'll run up to Sears tomrrow to get the easy out screw remover
Old Oct 16, 2006 | 07:19 PM
Hockey's Avatar
It is called an "Easy-Out".
Old Oct 17, 2006 | 06:46 AM
RadioZero's Avatar
i think "easy out" might be a trade mark name. i use the name because that's what most people seem to call them.
most tool places carry them, as described above they look like a cone with weird twisty "grippers". you drill a hole in the screw, insert the cone in the hole and run the drill in reverse and the "grippers" grab the screw and back it out.
Old Oct 17, 2006 | 07:16 AM
Hockey's Avatar
Agreed
chief01
Jun 18, 2015 01:55 PM
bjjs2k
Nov 4, 2010 07:11 AM
meth
Jan 26, 2005 10:50 AM
LowBudgetS2K
Jul 16, 2004 08:39 PM
