soft replacement , what you use ?
Old Nov 4, 2013 | 01:04 PM
S2KCHRIS305's Avatar
Default soft replacement , what you use ?
hey guys have any one of replaced your soft top, i need to do mine. wondering what you guys used? OEM, Robbins, EZ on. let me know im undecided
Old Nov 4, 2013 | 01:13 PM
jimi's Avatar
OEM w/modifry straps & rubber seals, installed by Billman while you wait
Attached Thumbnails soft replacement , what you use ?-blue-top-overhead3.jpg
Old Nov 4, 2013 | 01:26 PM
yeaa im shooting for oem , but im down to save by getting a robbins, only problem im scared of is the weight of it. is the robbins top heavier than oem? the cloth material has to be thicker. what you guys think?
Old Nov 4, 2013 | 01:42 PM
Not Sure's Avatar
Old topic:
https://www.s2ki.com/s2000/topic/901...s-oem-softtop/
Old Nov 4, 2013 | 02:18 PM
Originally Posted by Not Sure
ive seen this thread, still doesnt give me a solid answer. anyone know if the robbins is alot heavier than OEM?
Old Nov 4, 2013 | 04:32 PM
riceball777's Avatar
I have the ezon and I persionaly installed it about 4 years ago. I like it and it works fine. Everything fit perfectly and it's only a little over $400.
Old Nov 4, 2013 | 05:00 PM
i just ordered OEM . mine has lasted 8 years , that pretty fair i think to last that long
Old Nov 4, 2013 | 06:22 PM
User 2326's Avatar
I just did mine with Robbins top and modify straps. I don't see much difference between the Robbins top and the OEM that came on my 2006. The Robbins may be a little heavier, but not much. It also comes with a patch of reinforcement in the main wear spots, one on each side of the car. If you do the job yourself, it's a pretty big job but lots of good information on this board. Probably took me ~ 16 hrs to do it but I was working slowly and didn't mind taking my time.
Old Nov 5, 2013 | 04:38 AM
jimi's Avatar
Whatever you decide make sure you 'prep' the frame for any rough/sharp edges.and start applying protectant from day one. Good luck
Old Nov 5, 2013 | 04:58 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
My original oem top is 10 years old, 130k miles.
Not a single wear mark.
Key to soft top longevity is to limit sun exposure. Sunlight dries out the top, shrinks it, and makes it brittle.
If you have that big cumbersome top-down cover, use it. It is the best way to preserve your top.
All the tops I have replaced were yellow inside, from the sun.
