Soft Top HELP!
I replaced my 03 motor with one with less miles on it since then my soft top does not work anymore I have no clue as to why it doesnt work I have a test light and checked the power going to the switch and theres power for up and down the hazards work too no problem i checked all the fuses under the dash ( dont kow if theres a reason but i did ) and everything is fine but when I push the button nothing and yes im stopped and e brake is up i tried car on and car off still nothing no sound at all when i push the button please help
check for power at the motors then.
im not sure if this applies to S2000's but i work at a VW dealer and on our convertables, if there is a malfunction with a window, the top wont operate, so make sure your windows go up and down ALL THE WAY as well.
same issue happen to mine. sometimes it works but sometimes not. what i did is disconnected the safety switch under dash passenger side and plug it back and it work as it should. but now it's not working again.
