Soft Top Questions
Originally posted by joeschmoe714
Can you still use the soft top with the hard top?
thx!
thx!
A: No, just lower the soft top and the hardtop fits on top (no mechanical changes required)
Q: When the hard top is on the car is there anyway to operate the soft top?
A: No, there is a safety cut-out to prevent accidental operation.
Q: I only want to use the hard top in winter, is it difficult to get the soft top working again after I remove it?
A: No, the soft top will work as soon as you remove the hard top. The only difficulty is finding somwhere to store the hard top when not in use
[/QUOTE]There is a procedure for raising and lowering the soft top in the event that the motors quit working for whatever reason, so I guess it is possible. [QUOTE]
what is the "procedure" of lowering the top manually? is it just unpluging the switch on the passengers side anf then push down the top by hand? of there is another way of getting down the top.
I think that the manual says only for raising manually the top and not lowering it.
anyone?
anyone?
