Spark plug
Old Jul 29, 2008 | 12:05 PM
esmith51's Avatar
I just swaped over to NGK laser iridiums and loving them.
Old Jul 29, 2008 | 12:06 PM
EOE's Avatar
EOE
My suggestion is to do plugs every 20 to 30k miles to keep silky smooth idle and her running great. Changed my plugs at 45k and they did not look too good. I am at 73k right now and planning on doing my plugs soon.
esmith51... Where can I find those?
Old Jul 29, 2008 | 12:16 PM
Bob A (SD)'s Avatar
Like several have already mentioned, 30k seems a good time to change plugs. I'm planning a modified 30k service on my '03 S2K which will include valve adjustment and plug change. I've already bought them too:
NGK Iridium IX BKR7EIX-11 #6988.
--Bob
Old Jul 29, 2008 | 12:23 PM
blkwidow's Avatar
Pulstar
NGK
Old Jul 30, 2008 | 01:57 AM
damuho's Avatar
I just checked the plugs on my AP2 and they are Denso PK22PR-L11S. Why aren't Densos mentioned here? Are the NGKs better?
Is it normal to see some burnt stains on the insulator (between the insulator and the metal case)?
Old Jul 30, 2008 | 09:32 AM
EOE's Avatar
EOE
better off replacing them, and with S2k go with NGKs instead of Densos. Especially if you are going iradium, Denso's electrodes been known to break off inside the cylinder and causing engine damage.
I will be going with NGK.
Old Sep 16, 2008 | 11:48 AM
MsPerky's Avatar
Community Influencer
My primary care physician seems to be a gearhead. When he found out I drive an S, he told me about Pulstar plugs and said they were great for my car. He showed me their website, which I knew nothing about. Blkwidow - why do you not like them? Not sure where the fuel efficiency data he showed me came from, but it said Pulstar increases it by 13.5%.
Old Sep 16, 2008 | 11:59 AM
EOE's Avatar
EOE
Plugs alone increase fuel efficiency by 13.5%?....
Old Sep 16, 2008 | 12:00 PM
blkwidow's Avatar
Old discussion. I'll see if I can find some topics. Some people had problems with a CEL. Only like one 3rd party dyno run and it didn't do anything.
Old Sep 16, 2008 | 12:29 PM
N2oExpresS2k's Avatar
Supposedly they make power. I'll stick with OEM plugs untill more guinea pig's try them out tho.
https://www.s2ki.com/forums/index.php?showtopic=627649
