Spark plug comparison - pictures
Old Oct 3, 2004 | 08:26 PM
  #41
CwestinAP1's Avatar
Today I just switched my spark plugs to Bosch Platinum 2's. Whoa what a difference. These plugs came pregapped from Bosch so all you need to do is torque them in to spec. I highly recommend these spark plugs. They cost only $3.99 each and they are double platinum coated!
Old Oct 3, 2004 | 09:24 PM
  #42
xviper's Avatar
All plugs come "pre-gapped" but they may not have the correct gap for our cars. Several differenct kinds of cars may utilize the same part number for those plugs. You should always check them with a feeler gauge before installing. Also, depending upon if you are running F.I. or not will determine what the gap should be.
Old Oct 3, 2004 | 10:32 PM
  #43
CwestinAP1's Avatar
yep, these were already gapped to spec . Part# 4303 "PLATINUM2 VTEC; F20C1; Do not Gap " "Electrode gap is factory set Provides ease of installation - never requires adjustment"as it says on Bosch's website. double checking is always good tho, but it is not necessary w/ these 4303 plugs. has anyone else tried the bosch platinum 2's?
Old Oct 4, 2004 | 09:18 AM
  #44
hans's Avatar
Yes, I use the Bosch Platinum2 and have no problems with them.
My engine is stock with a homebrew intake (3" PVC pipe and a generic conical filter in an air box) and a butchered Honda header (to fit in my non-Honda car). Using the Bosch Platinum2 plugs and and an AEM ECU, I see a bit over 220 hp at the rear wheels with a DynaPack dyno. That's at just over 8500 RPM. No misfiring there!
With modern electronics and a coil sitting on top of each plug, I've got to wonder if misfiring is ever a problem with the F20C.
Old Oct 4, 2004 | 12:18 PM
  #45
CwestinAP1's Avatar
220rwhp, wow. Good to see someone else likes the Bosch Platinum 2's.
Old Aug 22, 2005 | 06:49 PM
  #46
xviper's Avatar
I needed to link this thread for someone and it reminded me to post the following:
A couple weeks after I came back from my 3500 miles driving vacation, my engine developed a very faint miss in the high rpm range, under load, WOT. It was not enough to throw a CEL but it still have me concerned. I was still running the IK-24s since I started this thread. I took them out and they looked quite "normal". Replaced them with an old set of the cleaned off NGK coppers. The miss has disappeared and has not returned now after a couple more weeks of driving.
I'm not sure what conclusion I can make at this point. Just a heads up for you folks.
Old Aug 23, 2005 | 03:30 PM
  #47
blackfx35's Avatar
Please keep us posted.
Old Aug 24, 2005 | 12:41 AM
  #48
RACER's Avatar
Thank's for being the guinea pig and providing input Dave. I once considered Irridium's, but I think I'll stick to the platinum plug's
Old Aug 24, 2005 | 06:19 AM
  #49
xviper's Avatar
[QUOTE=RACER,Aug 24 2005, 01:41 AM] Thank's for being the guinea pig and providing input Dave.
Old Oct 2, 2005 | 02:41 PM
  #50
Amuse Boy's Avatar
Ive rcently instgalled some NGk iridium racing plugs. I`ve noticed that the idling along with the power delivery is much smoother. I was going to install the Denso Iridiums but was told not to by J's Racing. Anyway some pics for comparison:
