Spark plug problem
Old May 25, 2010 | 12:47 PM
Saki GT's Avatar
Originally Posted by INDYMAC,May 25 2010, 03:53 PM
Did you try to gap the plugs before installing them? This is a no no for this exact reason. The laser platinum plugs are prone to break if you try to gap them yourselves. Make sure they are the proper gap from the factory, or don't buy them.
The center electrode on our plugs is slim and will break, not the outer electrode - that's why you need to use a wire gapper. But still, I agree - I'd rather not have to adjust gap than adjust it and weaken the outer cathode.
if the engine is running fine, I wouldn't lose sleep over it - you'll probably get more debris in the cylinder fiddling around than you would if you didn't.
Old May 25, 2010 | 02:01 PM
zeroptzero's Avatar
how old are the plugs ?, the electrodes can erode slowly over time and they just basically wear themselves away. They don't necessarily break though it could happen.
Old May 25, 2010 | 02:12 PM
raymo19's Avatar
Originally Posted by wadzii,May 25 2010, 03:57 PM
compression test probably wont show a beat up valve seat or a slightly bent valve, you'd have to do a leak down.
Yeah - but we did check the valves too. All were still in spec.
Plus it was running so rough with the bad plug and coil pack that I thought I'd broken the motor.
Running like a top now.
Old May 25, 2010 | 06:37 PM
Js2kreationz's Avatar
I had the NGK ridiums replaced about 6 months ago. theres no way they would've eroded. my ignition coil should come in tomorrow and then i'll know. thanks for the help everyone! this is a great site
Old May 25, 2010 | 07:14 PM
chris_barry's Avatar
Plugs were not torqued correctly resulting in poor heat conduction to the head. Plug overheated and also overheated the coil pack.
I would install new plugs on all cylinders and make sure they are correctly torqued, or even slightly over torqued.
There was a TSB on this ages ago.
Old Jun 3, 2010 | 09:57 AM
I replaced the ignition coil and the car runs and sounds perfectly fine!!! woohoo....
Old Jun 3, 2010 | 12:48 PM
s2klariat's Avatar
Old Jun 3, 2010 | 07:31 PM
INTJ's Avatar
Exactly, this happened all the time, but then they fixed it. Which is why you should never buy some random plug.
Old Jun 4, 2010 | 06:07 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Dont ever ask your engineer for advice on cars again.
Old Jun 4, 2010 | 09:15 AM
spectacle's Avatar
beat me to it
