Spoon calipers / bleeding !
I am sorry if this is a repost or whatnot but how do you bleed your spoon calipers, 2 bleeder valves on each calipers. And they are position upward. And can you use billman method ? thanks
Ok, a standard brake bleeding method i've done that, but i was trying use billman's gravity bleed method. But since the valves are positioned upward, i wasn't sure if its still going to work or not. Maybe i'll try it myself to see the result.
vroooom247
Jul 19, 2011 02:37 AM
