Spoon ECU problems???
Old Apr 1, 2002 | 08:42 PM
Gozita's Avatar
Default Spoon ECU problems???
Hi All,
I need some help, I installed the spoon ECU on sunday and my car wouldn't start
Is there anything else besides swapping ecu's that has to be done???
Tried install on 2 different S2Ks and neither would start! any suggestions will be helpful and very appreciated!!!
Thanks in advance,
G
Old Apr 1, 2002 | 08:53 PM
bayarea408's Avatar
its probably called a factory defect
Old Apr 1, 2002 | 08:59 PM
Gozita's Avatar
Your probably right, but I just wanna make sure I didn't miss anything.
It's a good thing the part is on loan from someone else
Old Apr 1, 2002 | 09:15 PM
Schatten's Avatar
I believe the Spoon ECU is just a rework of the Honda ECU. My guesses are the immobilizer key is still programmed into the ECU. I don't believe anything JDM specific (if you got it gray market or not) which would cause it not to startup.
Old Apr 1, 2002 | 09:52 PM
bayarea408's Avatar
where did you buy it from? and how much?
Old Apr 2, 2002 | 02:21 AM
biker1's Avatar
Someone posted about the same thing not so long back but I cant remember which forum? try do a search, but I seem to remember they sent it back eventually.
Old Apr 2, 2002 | 04:27 AM
turbo_pwr's Avatar
[QUOTE]Originally posted by Schatten
[B]I believe the Spoon ECU is just a rework of the Honda ECU.
Old Apr 2, 2002 | 06:42 AM
Gozita's Avatar
Thanks for all the replies!
Thankfully I didn't buy it It is on loan from someone else, it didn't work in his car either!
So yes, I agree with you guys, it's probably just broken!
OH WELL
Old Apr 2, 2002 | 10:55 AM
AJ PwR's Avatar
There will be no problems for the Spoon ECU that I assume. You need to bypass the factory immobilizer before you can fire up the engine. It is pretty much same immobilizer system as the 00-01 ITR.
Old Apr 2, 2002 | 04:43 PM
Gozita's Avatar
how do you bypass the immobilizer???
