sputtering / jerking under throttle...
Old Oct 7, 2013 | 05:09 PM
jsenclosure's Avatar
Default sputtering / jerking under throttle...
recently I have been experiencing some sort of an odd problem. I start up my car and it idles perfectly fine but when taking off my car will jerk almost like I am on and off the throttle, this happens through all the gears. if I put my foot to the floor and accelerate quickly it won't do it at all, it's only under low throttle/slow (low rpm) acceleration. Once the car warms up (a couple minutes of driving) it goes away completely. At first I was thinking my tb was getting stuck but now i'm thinking coil packs. I ordered another set of coil packs today and will try them out.
Any other suggestions?
fwiw I put a new iacv on it so I can rule that out.
Old Oct 10, 2013 | 03:30 PM
Changed my coil packs, didn't help
Old Oct 10, 2013 | 03:34 PM
s2000maniac's Avatar
I think it's the IAC valve especially if it's happening at lower RPMS.
Old Oct 10, 2013 | 04:20 PM
Doesn't happen at idle though, and it's a new iacv
Old Oct 11, 2013 | 09:43 AM
TheRook's Avatar
Did you check the spark plugs, clean the MAF sensor? Maybe you're just going too low in the RPM range.
Old Oct 11, 2013 | 10:01 AM
Mikey81's Avatar
Mine does that occasionally, I put it down to a very sensitive accelerator pedal, the ecu having different timing while the engine is cold and with my foot soo lightly on the pedal that any movement from the car causes the jerkyness.
My car has 42k just been fully serviced and drives as it should the rest of the time, but if there is a fault I will be sorting that so if others can confirm anything
Old Oct 11, 2013 | 10:13 AM
iamxpl's Avatar
have you tried resetting the ECU?
i would also check plugs if you havent already, we dont have a MAF sensor. did you check your droop or throttle cable deflection?
Old Oct 11, 2013 | 11:45 AM
I haven't checked plugs yet but I will be replacing them for good measure. My car is also on the stock comptech supercharger so i'm gonna check my belt tension again as well. I'm pretty sure it's not my throttle cable, it's nice and taunt and i'm not sure that would explain why the symptoms go away when the car warms up either.
Old Oct 16, 2013 | 04:08 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
It is definitely not coil packs.
Be sure your throttle cable is not over tightened also.
Old Oct 28, 2013 | 04:50 AM
any other suggestions?
