sqeeky clutch?
Old Feb 17, 2004 | 05:16 PM
FormerH22a4's Avatar
Default sqeeky clutch?
my clutch pedal when you push down on it has a squeek. It seems like the pivot plunger is dry or somehting.
Old Feb 18, 2004 | 03:46 PM
anyone??? I lubed a bit of the clutch pedal plungger but it still squeeks.
Old Feb 18, 2004 | 03:52 PM
Slows2k's Avatar
Is the squeak inside the car out outside?
Old Feb 18, 2004 | 05:12 PM
fly_S2K's Avatar
I get the same thing occasionally inside the car.
Old Feb 18, 2004 | 05:25 PM
Slows2k's Avatar
If the noise doesn't go away after lubing all the pivot points, It's probably coming from the clutch master cylinder itself.
Old Feb 18, 2004 | 07:23 PM
reds2's Avatar
I think you have to have the release bearing fork lubed. There was thread a while back on this.
Old Feb 18, 2004 | 07:24 PM
Slows2k's Avatar
That's inside the transmission, not inside the car
Old Feb 18, 2004 | 10:31 PM
great! they have to lower the tranny one more time. I had the 2nd gear synchro fix and now more headaches.
Old Feb 18, 2004 | 10:34 PM
Slows2k's Avatar
Is you noise inside the car or outside?
Old Feb 18, 2004 | 10:36 PM
more inside..
