squeeky springs
Old Mar 16, 2007 | 11:59 AM
07s2kap2's Avatar
Default squeeky springs
Hey guys I recently purchased a brand new 07 s2k. When i ride slowly over speed bumps i hear my springs squeek. is that normal? will it go away? has anybody else experienced these problems?
Old Mar 16, 2007 | 02:17 PM
VAD's Avatar
VAD
Check the springs for spacers. S2000's are shipped with spring spacers in them which can be dangerous if not removed.
Old Mar 17, 2007 | 12:00 AM
Suzukuh's Avatar
Yea you may as well check for spacers. I had 2 left on my car 53K miles later . Other wise the squeak I had on my car was from the hood latch. Adjusted it and now no squeaks. Other then that if your car is new I would take it to the dealer and ask them to diagnose it. Its under warranty.
Old Mar 17, 2007 | 06:53 AM
milkbubble's Avatar
https://www.s2ki.com/forums/index.php?showt...pension+spacers
Old Mar 25, 2007 | 12:27 AM
07s2kap2's Avatar
so to follow up on this thread. i took the car in and they said it was the rear strut taht was making the noise so the had to order it and they are going to replace it. WTF in a brand new car... is this possible???
Old Mar 25, 2007 | 01:03 AM
Suzukuh's Avatar
Could have just been a defective part to begin with. Let them replace it and see if that fixes it, if so you are good to go .
Old Mar 25, 2007 | 04:54 AM
brimstone's Avatar
squeaking at slow speeds over small bumps -- had it too. turns out it was my front right upper arm bolt that needed a bit squeezing. tell them to tighten all your suspension bolts before anything else.
Old Mar 25, 2007 | 01:46 PM
Mr. S2k's Avatar
You should grease rear sway bar mounts rubber. This is very easy. You need 14mm wrench. Unbolt 4 bolts, remove rubber from mounts and grease them.
Old Mar 25, 2007 | 10:21 PM
07s2kap2's Avatar
wow thank you mr. s2k for the great info
learnerspermit
Jul 17, 2011 07:24 PM
DCM
Jan 19, 2011 05:32 PM
pookie0744
May 17, 2005 04:17 PM
Ludatic
Nov 7, 2001 02:33 PM
