Squeking brakes
Old Mar 13, 2004 | 02:09 PM
S2000_rider's Avatar
Default Squeking brakes
So I flushed out my brake fluid and replaced all brake pads with Hawk HP Plus. I also applied the recommended anti-squeak brake grease as well....However, whenever I come to a rolling stop, the brakes squel pretty loud!? Could it be the new pads?
Any other ideas?
Thanks!
Old Mar 13, 2004 | 05:27 PM
TrueDrezzer's Avatar
Could be. Some sport / race compounds will squeal no matter how much grease you put on them, shims or not.
Once the pads have run a few hundred miles, you can bed them in by doing some hard stops and this might reduce the squeal.
Oftentimes you can simply do a few hard braking exercises to temporarily remove the squeal, too.
///Robin
Old Mar 13, 2004 | 06:31 PM
spesrf25's Avatar
you might need to have your rotors cut...mine were squeaking a lot till i had them cut...then they were fine
Old Mar 14, 2004 | 04:07 AM
TommyV's Avatar
You replaced your pads - but did not have your rotors turned??
Mine sqeeeeeeek bad sometimes too, and I tried all the anti-squeling compounds I could find. No luck.
I'm replacing all the pads and all the rotors.
Old Mar 14, 2004 | 12:48 PM
Ludedude's Avatar
Administrator
The Hawk HP Plus is a high-performance HPDE type pad. As with all such pads, they dust a lot and squeal on the street since they're cold. You usually can't heat them sufficiently on the street to make that stop for the most part.
Get used to it, it's not going away.
User 4225
Aug 25, 2014 06:04 AM
BrakeExpert
Mar 10, 2010 03:51 PM
JTNY
Jun 1, 2008 11:22 PM
Valentino007
Aug 13, 2007 12:31 AM
monkeymaker
Jul 21, 2002 06:23 AM
