srs light is on?
Old Dec 4, 2009 | 10:27 AM
Leadhead16's Avatar
Default srs light is on?
Is there a way to reset it so it goes off?
Old Dec 4, 2009 | 10:37 AM
AMS MIKE's Avatar
its on for a reason....
accident? unplug something? remove your steering wheel?
Old Dec 4, 2009 | 11:47 AM
Leadhead16's Avatar
I installed a hard dog roll bar and had to unplug it so now it wont go off
Old Dec 4, 2009 | 07:12 PM
Kirpich's Avatar
There's a 2pin yellow connector that doesn't connect to anything but just is plugged into a dummy holder slot in the fusebox. Pull it out. Short it with a paperclip. turn IGN ON.
When SRS light will go off after a few seconds, real fast, unplug the jumper.
When SRS goes on again, real fast, plug the jumper back in.
It will go off again, unplug real quick.
At this point, the SRS light should flash 2 times. Turn IGN OFF. Wait a few seconds. Then you should be good to go.
Old Dec 7, 2009 | 07:27 AM
Leadhead16's Avatar
I will give this a try.
Old Mar 25, 2010 | 01:37 PM
cvedral's Avatar
I saw this old post and dont understand it can someone explain it further.
what yellow connector in fuse box?
Old Mar 25, 2010 | 02:08 PM
vader1's Avatar
Or you could be like me........
I had to drop the steering column to install a gauge and broke the cable reel. If you cruise control or horn also don't work, that might be your problem.
Old Mar 25, 2010 | 03:32 PM
cvedral's Avatar
oops, found it. now making my own jumper i read something about using a 2 ohm resister??
Old Mar 29, 2010 | 12:11 PM
viets2000's Avatar
no, you have to reset your srs module. The 2ohm resistor is only to PREVENT it from coming on. Once the SRS light is on, you must perform the reset procedure that Kirpich stated.
Old Mar 29, 2010 | 09:00 PM
Chris S2K's Avatar
I just reset my SRS light using a paper clip. Took less than 2 minutes on 2 attempts.
