stale gasoline in s2000
Old Sep 12, 2011 | 10:13 AM
xasrielx's Avatar
Default stale gasoline in s2000
hey i've been storing my s2000 for about a year now. i know i will need new tires for it but i had 1/4 tank in it and i know it went stale. what should i do to keep my fuel system from gettin messed up from it?
Old Sep 12, 2011 | 08:46 PM
dsthez's Avatar
fill it up with chevron at your house dont drive it to the station...
Old Sep 13, 2011 | 06:22 AM
xasrielx's Avatar
so mixing the 1/4 tank of stale with 3/4 of fresh gas will be fine to run through my fuel system and engines
Old Sep 13, 2011 | 07:08 AM
WarrenW's Avatar
I don't know if Stay-Bil will work or not since it's been so long but you might want to give that a try. Read the label on the back or mayb e the info will be on their website.
Old Sep 13, 2011 | 07:24 AM
Vanishing Point's Avatar
If you are sure it is "stale" gasoline I would try to remove the old gas from the tank first. With a 1/4 tank a fair amount of condensation could have formed within the tank and this water needs to be removed. Try to get as much old fuel from existing lines as well and then put some new fuel in the tank.
Old Sep 13, 2011 | 07:25 AM
JackS's Avatar
Next time you store it for a long period, fill the tank all the way up to the filler neck and add a bottle of Stabil. This will lessen the surface area exposed to the atmosphere.
Old Sep 13, 2011 | 12:19 PM
xasrielx's Avatar
well idk if its stale or not for sure but it's been sitting for a year so i assumed it was. i will just drain out the fuel and replace it. ya hopefully i wont have to store it again though
Old Sep 13, 2011 | 05:23 PM
TonysMI4's Avatar
If your on a return fuel system then unplug the return line and run an extra line from that to a gas can and turn the key HALF way DO NOT hit the start!. All the gas will flow threw the lines and back out into your gas can. Refill and your good.
If your on a returnless fuel system then.... Unplug the fuel line from right under the motor. Run a + 12v wire to the + on the top of the fuel pump and the pump will run all the gas threw the line into your gas can.
USMC s2k
May 19, 2012 02:26 AM
Master Apex
Oct 19, 2009 04:03 PM
darkknight1999
Apr 30, 2005 04:51 PM
Kens_s2000
Oct 1, 2004 12:05 PM
