Stalling questions
Old Apr 5, 2003 | 09:07 PM
RazorV3's Avatar
Default Stalling questions
My friend recently bought a new RSX and is learning to drive a stick( ), anyways i told him to be careful about stalling...since it can damage the car if its done excessively. what are the exact parts that can get damaged everytime you stall? also, he wants to know if stalling once in a while is ok...for instance if a person is just not paying attention at a traffic light.
thanks in advance.
Old Apr 6, 2003 | 08:26 AM
xviper's Avatar
In the circumstances which you describe (low rpm, moving off from a stop), there should be no ill effects from stalling in this fashion. Some people might be concerned about clutch wear but the clutch gets much more wear during a normal take-off and certainly more wear from a non rev matched shift. And since at low rpm, the engine isn't developing a whole lot of torque or HP, stopping it like that should do no harm either. The only thing that I can see as even a slight issue is that the ECU may have a bit of a brain fart because it would have a hard time trying to maintain idle speeds as it would normally try do when the engine speed dips below its normal idle. If stalling out is not a regular long term occurance, the ECU won't have time to learn this odd behavior.
Old Apr 6, 2003 | 04:53 PM
RazorV3's Avatar
thank you very much for your excellent and informative post.
Old Apr 8, 2003 | 01:57 PM
dangarza's Avatar
Sorry guys. For a neurologist this is just so hilarious.
Lovely terminology Xviper....Keep 'em coming.
Daniel
rm7boy
Dec 30, 2006 04:23 PM
revlikcrazy
Jun 10, 2006 11:23 AM
andrewh_11
May 9, 2006 11:07 PM
specialk22tt
Dec 1, 2005 07:22 AM
S2000AD
Apr 27, 2004 06:05 PM
