Stock airbox install
I am gonna put my stock airbox back on my car to replace the AEM cai that is on it now. It was installed when i bought the car so i don't really know where everything goes. Can someone post close up pics of the stock intake so i can see where all the hoses that were removed for the AEM go.
I tried looking in the DIYs but it didnt really help at all
Three total 10mm bolts hold the housing down to the body. Two are on the left side (if you are standing at the front bumper). Third is on the opposite side. The only other thing I would say look out for is the vacuum lines for the airpump, make sure you look over the threads in the DIY section to route them.
good luck
good luck
It is pretty straightforward, just make sure that the wiring harness and the vacuum lines are correctly clipped in on the back side of the air box. also make sure that the solenoid is bolted into place. Otherwise any one of those things could end up in the engine accessory belt.
Also:
Also:
