Stock Intake
Old Aug 5, 2010 | 07:12 PM
KawaFord's Avatar
Default Stock Intake
I'm trying to put the stock intake system back into my car.
I currently have a AEM in there, that's how I got the car.
I was wondering if anyone could tell me how the stock hosing system works, I purchased one from another member.
I found this diagram, but where does the "E-8" section hook up to?
This is what my car currently has:
Old Aug 5, 2010 | 07:42 PM
JDMQuip's Avatar
That section mates up into the stock intake tubing. You will see the holes on the rubber intake pipe to where that piece goes
Old Aug 5, 2010 | 07:53 PM
Requiem's Avatar
I didn't know AEM made a SRI for our cars.
Old Aug 5, 2010 | 11:25 PM
energetic's Avatar
These two photos will give you a clue.
Old Aug 6, 2010 | 03:37 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
On your car that has the aem, there is one small hose running from the coolant bleeder screw, to under the throttle body. It is a coolant hose. It will need to be removed to put the stock tubing manifold (E8) back on.
Old Aug 6, 2010 | 12:50 PM
KawaFord's Avatar
Awesome.
Thanks for the help guys, appreciate it!
Here's what it looks like now
I accidentally dropped the cover on the driveway... :'(
I'll probably wind up painting it because it's driving me nuts.
Old Aug 6, 2010 | 02:20 PM
Billman250's Avatar
Top Answer: 1
you missed a few things
Take your map sensor wire, route it over the pipping manifold, and clip it in the intake snorkel.
Also, the wire harness has a small white clip. it goes in the empty hole in the piping manifold. Look closely at the above pic.
Old Aug 6, 2010 | 03:19 PM
KawaFord's Avatar
I did that after I took the pic, I had to take it all off again, threw a engine code for some reason.
I'm not used to what a stock setup sounds like, is it supposed to sound like a loud whistle noise all the time?
Or do I have some kind of leak?
I reset the code, and put everything back on tight, so we'll see if it throws it again... other then that, it runs fine, sometimes boggles at idle.
Old Aug 6, 2010 | 08:52 PM
JDMQuip's Avatar
One of your vacuum hoses looks to be undone.
Old Aug 6, 2010 | 10:40 PM
Seattle2k's Avatar
Nope, not suppose to sound like a loud whistle. Check those hose connections.
Oh, and you might be able to sand those scratches out.
