Strange Ignnition problem
Old May 20, 2008 | 05:02 PM
kledbetter's Avatar
Thumbs up Strange Ignnition problem
My 2002 S2K's engine threw the #1 rod through the side of the block @ 102K miles; so I found a replacement motor with 37K and installed it. After the installation seemed to go well, when I went to fire it up, the motor cranked but wouldn't start.
The first thing I thought old gas, so I emptied the tank, purged the lines and ran a couple of gallons of fresh gas through the fuel lines; it didn't help. With the Honda shop manual I went through the fuel system troubleshooting routine, nothing checked out bad.
I looked at the immobilizer system, everything looked fine.
When I ran a UBD-II scan on it, it passed without any codes. But to my surprise, the engine fired up and ran beautifully with the UDB-II scanner attached. As soon as I removed the tool; the motor died.
No codes diagnostic codes are returned. But the motor ONLY runs with the scanner attached. Does anybody have any ideas?
Kevin Ledbetter
Old May 20, 2008 | 05:10 PM
SIIK2NR's Avatar
Have you ever been to Athens Georgia?
Old May 20, 2008 | 05:16 PM
kledbetter's Avatar
Nope, never been to Athens; why do you ask?
Old May 20, 2008 | 06:10 PM
em ekohc's Avatar
We had an 06 civic do the exact thing at work after I replaced the short block, the problem with it was one of the grounds wasn't making contact and the scan tool was giving it a ground. Not the same car but its a start
Old May 20, 2008 | 07:16 PM
Slows2k's Avatar
I'd bet it's missing a PCM ground.
Old May 20, 2008 | 07:54 PM
SIIK2NR's Avatar
I know a Kevin Ledbetter is all.... just check'n.
Old May 20, 2008 | 08:21 PM
chrisesteban's Avatar
check the ground behind the head.
Old May 22, 2008 | 06:26 AM
kledbetter's Avatar
Thanks Guys! The ground wire on the back of the cylinder head was the problem. After removing the air control valve and un-attaching the wiring harness; I was able to get my hand and a wrench between the engine and the firewall to hook it up.
Old May 22, 2008 | 10:50 AM
1320performancefreak's Avatar
LOL i would never figure this out if it was me.
Old May 22, 2008 | 08:30 PM
R3DS2K's Avatar
maybe for me too.. i would have never tried to start it after hooking up a scan tool since it didnt start before ...
TonysMI4
Jul 5, 2011 09:31 PM
NSXOTIC
Apr 14, 2009 07:23 PM
jdmfbpsi
Nov 15, 2008 08:03 AM
ack5252
Jul 18, 2007 09:01 AM
mikecl713
Aug 14, 2005 01:37 AM
