Strange issue with locks
I recently started experiencing a strange issue with my driver side lock. If I unlock the car I can hear the lock disengage, however the moment I go to open the door and pull the handle (either outside or inside) it relocks. The only way to open the door is to push the unlock while pulling the handle. Another thing I notice is that the manual lock switch inside is always free floating, it does nothing. This just started out of nowhere and the only thing I have been doing is installing a roll-bar, which I dont think can be related. To me it seems logical that something is broke inside the door although it seems electrical and I don't want to tear the door apart for nothing. Anyone have any thoughts? |
Door comes apart super quick. Just do it!
https://www.s2ki.com/forums/s2000-ga...e-such-158388/ |
The manual lock switch has a piece that extends down to the metal rod that does that actual locking. That part is broken. Here's a pic from another user (forget who, sorry, but his thread is around here somewhere):
https://cimg9.ibsrv.net/gimg/www.s2k...67bf7eae44.jpg Unfortunately you can't buy just the switch, you have to buy the whole handle assembly. |
a bit off topic but, it is kind of funny i had to replace this on my 95 civic hatch recently and its like the same exact mechanism. I wonder if it is literally the same piece it looks almost identical
As twohoos pointed out, the plastic piece of the lock mechanism that connects to the rod breaks off. I've broken this twice now on my car in 2 autocross seasons. I have a tendency to clutch my left knee against my door panel while cornering. I thought I broke the habit this past year but, again, have broken door locks. I looked for over a month to find a used one on ebay last time around. It seemed there were many passenger side door handles available though driver sides were few and far between. I had to order one from Australia and pay shipping. Anyways, try to be conscientious of holding yourself in place with your left leg while driving hard. I am 99% sure that is the culprit of the issue. I've been wondering if I was the only one to have this problem...
Originally Posted by Jub
(Post 24411786)
Also have a problem with my driver side lock... can someone help me figure it out?
Its with the inside lock button... when I push/pull to lock/unlock, it does not go all the way. I have to slightly lift the inside door handle while push/pulling the button and then it locks/unlocks as normal |
Originally Posted by B KOO
(Post 24412700)
Its with the inside lock button... when I push/pull to lock/unlock, it does not go all the way. I have to slightly lift the inside door handle while push/pulling the button and then it locks/unlocks as normal 01 model with this issue |
Originally Posted by akirakun
(Post 24414297)
Same thing for me! When I hit the remote lock, hear the noise of stuff actuating... but doesn't lock. I have to manually partial hold the inside latch plus switch the lock. Just pushing the lock inside minus pulling the handle doesn't work. I was looking to buy a new actuator to fix this. Sorry OP, don't mean to hijack this thread.
Know I'm late to the party but I've just found the fix for this issue after hours of tinkering. You need to take the outer door handle off and thread the rod attached to the door handle out till its flush with the part it screws into.
Test it for proper alignment when u put it back in by locking and unlocking the interior lock. Should lock and unlock freely. I've broken countless interior plastic locks and had the same issues above. This fixed my issues. |
| All times are GMT -8. The time now is 11:21 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
