strange vtec issue
Old Jun 20, 2007 | 12:12 PM
  #31
tron1's Avatar
Originally Posted by heresnowhy,Jun 18 2007, 03:52 PM
me being over zealous with assembly lube, and it was in intake rocker, and no they were the original rockers..... I thought that might be the problem, but was dreading breaking her down that far again.....
Incredible.... I appreciate the diagnosis and repair/solution!
Old Jun 20, 2007 | 04:59 PM
  #32
jyeung528's Avatar
Originally Posted by AssassinJN,Jun 20 2007, 03:59 AM
Did you read the above posts?
lol, i can't read well.
any conclusions on why the pin got stuck?
Old Jun 20, 2007 | 07:45 PM
  #33
90crvtec's Avatar
But the OP already answered that question too....
Old Jun 20, 2007 | 10:46 PM
  #34
jyeung528's Avatar
too much lube?
what does that mean.
Old Jun 20, 2007 | 11:07 PM
  #35
RACER's Avatar
Originally Posted by jyeung528,Jun 19 2007, 11:57 PM
any conclusions?
[QUOTE=jyeung528,Jun 20 2007, 05:59 PM]
Old Jun 21, 2007 | 05:00 AM
  #36
heresnowhy's Avatar
Originally Posted by jyeung528,Jun 20 2007, 10:46 PM
too much lube?
Too much lube. It means when I disassembled the engine, all of the the moving parts were cleaned and dried. When you assemble and re install critical moving parts, you need to apply assembly lube to pieces with metal to metal contact for the initial startup. I had applied an excessive amount of molly lube on the vtec pins, which according to the manual should just be oiled but I was feeling crazy and threw some lube on them anyhow. Well that's why the manual says use oil, the thick, glue like lube galled and froze my pins, in the number three cylinders intake rocker arm. Hope this is a better description for you.
Old Jun 21, 2007 | 11:18 AM
  #37
jyeung528's Avatar
ah shet.
when i reinstalled my cylinder head... i didn't lube it up.
damnit!
i didn't read anywhere in the service manual that spoke of lubing that shit up.
Old Jun 21, 2007 | 01:10 PM
  #38
SpitfireS's Avatar
heresnowhy Posted on Jun 21 2007, 02:00 PM
It is (kinda) strange IMO - no offence - that the oil pressure wasn't strong enough to push the pins into "vtec position".
@ 6000 rpm there would be around 8 - 8.5 bar (120-125 psi.) of oil pressure.
After all the narrow passages you may end up with (?) 5.5 - 6.5 bar (80-100 psi) at the pins?
Pin diameter is (?) 7 - 8 mm?
That gives a minumum force of ... 20 Newton pushing the pin away.
Okay, minus the spring pushing back.
Lets say 17 newton = approx 3.8 lbf.
And all the parts are hot too.
Hmm...
Maybe you used glue instead of assembly lube?
jyeung528 Posted on Jun 21 2007, 08:18 PM
damnit!
No worries, they are lubed now.
Old Jun 21, 2007 | 06:29 PM
  #39
heresnowhy's Avatar
no offense taken, it seemed more like a vacuum holding it oddly enough. it took a rather strong magnet to get it free, possibly some debris lodged in it as well. Don't know really, but once I got it free and re assembled, she ran like a scalded cat.
Old Jun 22, 2007 | 06:09 AM
  #40
Willie Gee's Avatar
I thought it was a stabbed rat.
