stripped bolt?
Old Nov 1, 2006 | 08:22 PM
kikicha's Avatar
we'll ill sleep on what i'm going to do with this issue, thanks for all the helpful advice! i owe you one
Old Nov 2, 2006 | 02:01 AM
CoralDoc's Avatar
Before any attempts at removal, applying a penetrating fluid such as Liquid Wrench, PB Blaster, or equivalent (NOT WD-40). Let it soak in overnight and re-apply before trying to get the fastener off. Even if you're taking it to a mechanic, just doing this step will make it much easier to achieve success.
Good luck.
Old Nov 2, 2006 | 05:50 AM
Ek9's Avatar
Ek9
Banned
You can grind the head off too if you can get a file or grinder in there. As '2k says don't do it unless you have a bolt handy. Grind the head off, take off the housing then use vice grips to unscrew the stub.
Old Nov 2, 2006 | 07:33 AM
JDR159's Avatar
Go to Sears or Home Depot and have a sales person get you one of their extractor sockets for a 10mm bolt. This is the "cutting" socket others referred to. I wouldn't recomennd cutting the head off: From your posts, I don't think you have the mech. skills to deal with this.
Once you remove the bolt, take it to an autoparts store or Home Depot for a replacement. Confirm the new bolt is correct by using a common nut to screw both bolts into. You don't want to buy the wrong pitch bolt..
Old Mar 16, 2007 | 04:03 PM
jinn21's Avatar
The head of my differential fill bolt is kinda rounded off (not completely rounded off) but hard to take off. i have already ordered a new one.
I was wonering if anyone has advice before i give it another try.
Old Mar 16, 2007 | 05:18 PM
RedY2KS2k's Avatar
Did you read the posts in this thread?
Old Mar 16, 2007 | 05:33 PM
JackS's Avatar
I haven't been back to my diff. yet but you could try a large pair of chanel locks or vice grips. I'm sure there a some specialty tools you could find at Sears that would absoluty work.
liquidgsr
Sep 19, 2012 07:17 AM
kenstyle
Sep 24, 2006 03:39 PM
CaptinMorgan97
Oct 6, 2003 04:13 PM
