stripped diff drain bolt
Old Nov 11, 2013 | 06:27 PM
bhchase's Avatar
Default stripped diff drain bolt
I tried my best, but managed to strip the diff drain bolt. Cannot find a 24 mm bolt extractor. Any ideas ?
Old Nov 11, 2013 | 06:38 PM
fernando.'s Avatar
Try to hammer a smaller socket like a 23 or 22 onto the bolt, or possibly squeeze a small set of vice grips in there, or get a punch and make an indentation at the edge of the bolt then put the punch on an angle and try to spin the bolt out. Where there's a will, there's a way.
The main reason why bolts strip is due to putting constant pressure by pushing or pulling with the wrench/ratchet. You need to give the wrench/ratchet a smack with the palm of your hand to "crack" the bolt loose.
Old Nov 12, 2013 | 05:49 AM
spets's Avatar
Make sure you're using a 6 point socket and not a 12 point socket.
Might be a good time to pick up an impact drill or air gun
Old Nov 12, 2013 | 06:15 AM
bewareofthepoop's Avatar
Vice grips and a hammer! I have done this in my earlier days with my oil drain plug so just put the vice grips in and tap them with a hammer to get the plug to loosen. You will most likely destroy the plug so you will have to get a new one. but good luck!
Old Nov 12, 2013 | 07:36 AM
spets's Avatar
Good luck with that, there's no room to get vise grips on the diff drain bolt with the jack pad surrounding the bolt. 6 point socket and an impact should be able to get it off.
Old Nov 12, 2013 | 08:17 AM
iamxpl's Avatar
you might have to sacrifice a socket. i would try the punch first
freq
Apr 15, 2018 10:55 PM
i_luv_s2k
Dec 14, 2011 05:51 PM
bam9382
Apr 23, 2008 08:28 AM
RGlbk
Jan 5, 2008 02:45 PM
Riceboi
Mar 30, 2006 09:36 AM
