Stripped knock sensor
Did a tranny n clutch job, I broke the knock sensor, ordered an aftermarket sensor (should of got oem), the threading on the new sensor was a thought fit, after a few miles of driving, got a cel for knock sensor, went to inspect, it was loose, tried tighten it or loosen, no luck it just spins, seems like no threads are catching either way, there is a lil play with the sensor that I believe is throwing the cel code, I duck taped it to keep it still, that lasted about a day or so before the cel came back on, the heat from the motor made the tape not tight anymore, is there a way I can make the sensor stay in place or a way I can remove the sensor, any inf will help, thank you
Broke the sensor, now have the bolt stuck flush with the block, had to get a small dremel to make a hole so I could get the bolt extractor to catch grip, what pita!!! Lesson learn getting a oem sensor, the aftermarket one was made with poor quality,
Originally Posted by Mister Jew' timestamp='1333057179' post='21557348
Have it welded?
Easy fix might not be the best one though.
unowned
Apr 11, 2021 08:19 AM
