Stripped wheels stud!
Old Jul 23, 2010 | 06:46 AM
EK9MAX's Avatar
Default Stripped wheels stud!
Crap, ok well somehow I stripped one of my wheels studs on my rear left wheel.
I heard you pretty much have to replace teh wheel bearing when doing the wheel stud......
I'm going to get this done, but I have a lapping day event this weekend. Am I ok to run with 4 wheel nuts for a while?
I actually have 5 on there, but the 5th won't tighten all the way....
433whp/290wtq
Old Jul 23, 2010 | 06:52 AM
IlleztImportz's Avatar
when this happened to me, i was recommended to limit my drives to short ones and avoid high speeds. if you have access to a shop, it shouldnt take long for them to press in a new stud. as for the wheel bearing, doesnt have to be changed out but is recommended while the hub is out.
Old Jul 23, 2010 | 07:59 AM
s2000maniac's Avatar
no worries... 4 lugs will do just fine....hell even 3 would be fine too....i mean about half of the cars out there have 4 lugs....just coz the car was designed to go on 5 lugs doesnt mean it wont run on 4 lugs.
Old Jul 23, 2010 | 09:30 AM
TopGear's Avatar
Originally Posted by IlleztImportz,Jul 23 2010, 10:52 AM
...as for the wheel bearing, doesnt have to be changed out but is recommended while the hub is out.
It's a sealed bearing that's broken open when you remove the hub. There's no way around replacing the bearing if you're taking the hub off for any reason.
Old Jul 23, 2010 | 09:38 AM
2poor2mod's Avatar
Don't listen to this guy get it fixed asap
Old Jul 23, 2010 | 09:59 AM
e3opian's Avatar
Trolling for laughs is one thing, but to recommend something unsafe which puts the driver and other drivers sharing the circuit in potential harm's way is just shameful.
Old Jul 23, 2010 | 10:02 AM
goldenfri's Avatar
Its ok to drive easily on for a little while, like to a shop, but I would never take it to a track day with only 4 lugs. You are putting the max possible stress on the lugs doing this and they are far more likely to fail. Cars that have only 4 lugs have them evenly distributed, if you are missing a lug this is no longer the case. I wouldn't trust my life to only having 4, especially if you have as much power as you say. I don't think you can even pass tech missing a lug.
Old Jul 23, 2010 | 10:05 AM
SpitfireS's Avatar
It's safe to drive to the dealership / workshop, but a trackday......
NO!
Old Jul 23, 2010 | 10:12 AM
00CivicSi's Avatar
Old Jul 23, 2010 | 10:34 AM
TopGear's Avatar
I agree with that, and what all the other sane people have said. See if you can get the lug replaced tomorrow, or don't do the track day.
I've read that if you just need a single stud replaced, that the dealer can sometimes do it without taking the hub off (I'm not sure how they accomplish this, but I read it more than once when going through wheel stud threads recently)
