Strut Tower Brace
Old Feb 18, 2008 | 01:56 PM
DeeDubya's Avatar
Default Strut Tower Brace
I searched and found plenty on strut tower braces but could not find what to do about taking up the slack.
With the brace in place and all bolts still loose you can push-pull on the brackets and get at least 1/4" maybe 1/2" slack over the length of the brace including the pivot bolts.
With the car on a flat level surface, should I pull the brackets outward before tightening or push them together before tightening? This should be determined by the direction that will receive the most pressure. I would imagine that when cornering the top of the outside strut tower would tend to lean outward and away from the other. If so then it seems that I would pull the brackets apart before tightening?
Any thoughts?
Old Feb 18, 2008 | 05:43 PM
Ludedude's Avatar
Administrator
When cornering, there's exactly zero pressure on the top of the shock mounts. This car doesn't have struts, there's no load path to the top of the shock like there is in a strut suspended car.
Just tighten the thing up and use it to lean on when changing the oil or working under the hood.
Old Feb 18, 2008 | 06:20 PM
S2Race's Avatar
so strut towers are useless on s2000s basically? what about ones with Xbraces that go all the way to the bottom of the chassis as well?
Old Feb 18, 2008 | 06:41 PM
Slows2k's Avatar
Equally useless.
Old Feb 18, 2008 | 06:43 PM
qbmurderer13's Avatar
At least its pretty
Old Feb 18, 2008 | 06:49 PM
Slows2k's Avatar
They like to get in the way, especially the 4 point ones that bolt to the steering rack.
Not to mention weigh the car down, and lighten a wallet.
Never on my car.
Old Feb 18, 2008 | 06:59 PM
S2Race's Avatar
i figured they would help stiffen the chassis which leads to less chassis flex. good on the track. but they are completely useless? wow... might get a cheapo just for show then...
Old Feb 18, 2008 | 07:06 PM
IlleztImportz's Avatar
i just learned something new
Old Feb 18, 2008 | 07:10 PM
S2Race's Avatar
same here... thats a shock to me. how could stiffening everything not help?
Old Feb 18, 2008 | 07:11 PM
Slows2k's Avatar
You can pick up an S2000 from 1 lift point and get the entire side of the car off the ground, and still open the door easily.
Chassis flex is not a issue, considering the car has no fixed roof.
