Stupid Squeek
Old Nov 13, 2009 | 05:38 AM
rosscoe21's Avatar
Default Stupid Squeek
I have this squeek coming from the front of my car. Almost like the squeek of one of those dorm room beds when your havin at it with a lady friend. I am convinced it is in the suspension. It usually only does it when it is cold and it seems to get worse when it is wet out. Any time I hit a bump or uneven spot in the road it does it. It's more evident when I am going very slow. I can't replicate the noise when the car is parked no matter how much I shake the car around. I have had it to Honda ten million times and they can't seem to find the problem. I even took the tech out and had him listen to it. I keep thinking maybe it is the bushings. But they refused to replace them. Any Ideas?
Old Nov 13, 2009 | 06:25 AM
dammitjim's Avatar
Try white lithium grease on the hood latch mechanism
Old Nov 13, 2009 | 06:52 AM
rosscoe21's Avatar
Will do. Honda was supposed to have done this already.
Old Nov 13, 2009 | 09:33 AM
rosscoe21's Avatar
It really sounds like it is coming from the wheel area.
Old Nov 13, 2009 | 09:40 AM
cannonball's Avatar
Might try cleaning and re greasing the swaybar bushings.
Old Nov 13, 2009 | 09:42 AM
dammitjim's Avatar
I thought I had a swaybar squeak and it was the hood latch. Mine sounded like it was coming from anywhere but that latch.
Old Nov 13, 2009 | 04:51 PM
rosscoe21's Avatar
I will try that. After I grease the latch. This thing is pissing me off. I also have a slight rattle at times and can't figure out where it is coming from.
Old Nov 15, 2009 | 06:30 AM
clag's Avatar
My experience as well. At times I swore it was coming from under the passenger seat. Little grease on the D-hook for the hood and all is good.
Old Nov 20, 2009 | 06:08 PM
rosscoe21's Avatar
Greased the bushings on the sway bar. The noise isn't as bad but its still there. I guess I could replace the bushings.
Old Nov 20, 2009 | 06:24 PM
fasttech's Avatar
just goin over bumps or turning.. take it to differant dealer or they should use chassis ears to find the squeek
