super cuise control
Old Jan 15, 2009 | 08:02 AM
milkman2089's Avatar
Arrow super cuise control
my s2 is acting funny
it seems to be on cruise control all the time but at 4 mph
it does not stall if i take my foot of the gas in 1st gear it just keeps on rolling at 4mph
and cruise control is NOT on
i just got my car back because it was supposably getting fixed good thing my warranty covered it but the problem still continues anyone have had a similar problem or can anyone help diagnose the problem?
Old Jan 15, 2009 | 08:34 AM
SgtB's Avatar
That's normal. Even an automatic will do that. Your engine still makes power at idle, and as long as the clutch is engaged, power is being transferred to the wheels. Now if it happens in neutral you have problem.
Old Jan 15, 2009 | 11:10 AM
emdzey01's Avatar
what's the idle speed?
and maybe your throttle cable is on too tight
Old Jan 15, 2009 | 11:29 AM
Blendo's Avatar
Super Cruise = Fly at Mach speeds without afterburners?
Your 'car walking' sounds normal.
Old Jan 15, 2009 | 11:36 AM
ts80's Avatar
Milkman, is this your first car?
As far as I know, all cars, manual and automatic, will creep forward when in gear and clutch engaged...given that the ground is flat enough that you don't stall.
Old Jan 16, 2009 | 06:35 AM
takeshi's Avatar
I have to agree. Sounds like the problem is in the driver's seat.
Old Jan 16, 2009 | 07:07 AM
VAD's Avatar
VAD
Get a new torque converter.
j/k Your car's fine
Old Jan 16, 2009 | 07:09 AM
vtec9's Avatar
Does this happen all the time, or just when the car is cold, and the idle is being held high by the ECU? You should idle around 900 rpm. Much more than that is too high, and will make the the car drive itself faster.
Old Jan 16, 2009 | 07:39 AM
EVAN&MONICA's Avatar
Yea on really cold mornings my S will drive uphill at around 10mph with no throttle input
Old Jan 16, 2009 | 11:13 AM
magikcow's Avatar
they make cars like that so you can ghost ride the whip
