Suspension Torque Specs
Old Aug 10, 2005 | 04:32 PM
WarrenW's Avatar
Default Suspension Torque Specs
Unless I missed something in the Helm's Manual, I can't seem to find any torque specs for the suspension components. I found a few loose bolts and I need to tighten them before some drastic happens.
Thanks,
Warren
Old Aug 11, 2005 | 04:59 AM
WarrenW's Avatar
Bump
Old Aug 11, 2005 | 08:57 AM
Kel's Avatar
Kel
You'll have to be alittle more specific then that. Maybe pictures will help.
Old Aug 11, 2005 | 09:03 AM
AJ PwR's Avatar
PM me and tell me which bolt you are talking about and I will be able to give you the torque specs
Old Aug 11, 2005 | 10:34 AM
WarrenW's Avatar
Sorry, I basically mean ALL bolts (I know different bolts have different specs). After noticing some were loose, I decided I should check all of them but I can't find any info on which ones to torque to what.
I remember an episode of Sports Car Revolution on Speed Channel that mentioned checking all suspension bolts after each track day. And after 2 track days and 3 yrs worth of autocrosses along w/ the car being 4yrs old and 80,000 miles on it, I figure it was past time to start checking the bolts.
Some of the bolts I'm thinking of are:
The lower crossmember brace (has 3 bolts on each side)
the entire front suspension subframe bolts
the transmission crossmember bolts
A-Arm bolts where they attach to the brackets that are welded to the car
any other suspension bolts that I missed on this list
Warren
Old Aug 11, 2005 | 12:47 PM
Gloffer's Avatar
Those torque specs are all located in the Helm's Manual. Most of them are in the suspension section, and the rest are in the body/chassis section.
I'm at work and don't have my Helms available, but I'm sure I've seen those torque values listed in the manual. If you have a Helms, then look a little more thoroughly and I think you'll find the values. If your still having trouble, I'll help you out tonight when I get home.
Old Aug 11, 2005 | 05:46 PM
WarrenW's Avatar
Yep, you're right Gloffer. I found them underneath diagram where it mentions bolt size. I didn't even see it under there, all I saw was the bolt size. I wasexpecting to see the specs in a seperate chart or something like that. Thanks again...now back to work.
Warren
Jake89
Sep 11, 2015 09:39 AM
FISH22
Aug 24, 2006 01:26 PM
Rhino80
Mar 3, 2006 03:49 AM
WarrenW
Aug 11, 2005 05:00 AM
Mr. Francesco
Dec 8, 2004 07:40 PM
