Symptoms of incorrectly gapped plugs?
What are the symptoms of incorrectly gapped plugs? Are there different symptoms for plugs that are off gapped a little or alot. Or is it the same symptoms in either case?
I'm not following your reasoning.
Pull them out and check the gap. If they are what they're supposed to be for your application, then any problems you may have must be attributed to something else.
Too small a gap and you'll get early fouling. The plugs won't fire well because there is too much crud in the space.
Too big a gap and the spark can't jump properly and you get a miss, usually at higher rpm.
In both cases, the symptoms from the driver's seat will feel similar.
Well my car doesn't seem to pull like before and it also feels the car is not reaching redline as fast as it used to.
Also the vtec doesnt feel as powerful.....but I am not getting any miss at high rpm.
That's probably not the gap.
Too wide a gap gives a drooping idle and slight miss. I played with wider gaps and found I didn't like that sensation so gapped back to normal. I would have expected the miss to be at higher rpms but didn't find that, all my symptoms appeared at or just off idle.
This is a cut and paste from the NGK website:
Since the gap size has a direct affect on the spark plug's tip temperature
and on the voltage necessary to ionize (light) the air/fuel mixture, careful attention is required. Those with modified engines must remember that a modified engine with higher compression or forced induction will typically require a smaller gap settings (to ensure ignitability in these denser air/fuel mixtures). As a rule, the more power you are making, the smaller the gap you will need.
A spark plug's voltage requirement is directly proportionate to the gap size. The larger the gap, the more voltage is needed to bridge the gap. Most experienced tuners know that opening gaps up to present a larger spark to the air/fuel mixture maximizes burn efficiency. It is for this reason that most racers add high power ignition systems. The added power allows them to open the gap yet still provide a strong spark.
With this mind, many think the larger the gap the better. In fact, some aftermarket ignition systems boast that their systems can tolerate gaps that are extreme. Be wary of such claims. In most cases, the largest gap you can run may still be smaller than you think.
Originally Posted by Fasttimes!!,Apr 6 2006, 08:48 PM
How does this help with my inquiry????
Have you even pulled your plugs and inspected them???
Well I took out the plugs and good thing I did. My car wasnt running well and come to find out the plugs all ranged from .045-.049 in gap. When I bought the plugs from Honda the parts person said they were pregapped. I didnt even ask that. But they made a note to say that. I didnt question it. I learned my lesson. Next time check them first. I purchased a .50 cent piece size gapper. Cost me $2.
Also I have a 1/2 inch torque wrench and use a 1/2 to 3/8 adapter so I could fit my extension and sparkplug socket as they are all 3/8's.
My question is if I use a adapter will I loose foot lbs in regards to accuracy?
