Tail Lights
Old Dec 21, 2004 | 11:47 AM
vpn2001's Avatar
Default Tail Lights
I was informed that my right rear brake light was not working. OK, I'll just replace the bulb. Replaced the bulb (the one with two filaments). Rechecked the brake lights, no good. Must be a bad replacement bulb. Replaced with another new bulb. Still no good. Must be the fuse. Checked the fuse, it was good. Must be the bulb socket, checked that; it was good. The left rear and center brake lights works when the brakes are applied. All three works when the park light is turned on. Checked the wiring harness with a test light...the park light works and the brake light doesn't. Do I have an open wire somewhere? Any ideas? Will the dealer fix this under warranty?
Old Dec 21, 2004 | 12:51 PM
xviper's Avatar
As long as you haven't done anything that could be considered altering the wiring, then I should think they will fix it.
Old Dec 21, 2004 | 03:13 PM
Slows2k's Avatar
Take the car in. You really need a wiring diagram and a multimeter to troubleshoot this circuit correctly.
rsStewie
Apr 29, 2016 03:07 AM
Hs2ktc
Feb 21, 2016 01:51 PM
K1ngfunK
Aug 28, 2007 06:28 PM
ace039
Jul 15, 2006 11:09 PM
