TDC sensor location
Old Dec 21, 2015 | 05:43 AM
mhollifi's Avatar
Default TDC sensor location
I was having cel code 1366 so switched TDC sensors locations (swapped positions). Now code is 1362 and 1367. Which sensor is Honda referring to as #1 sensor vs #2 sensor. Thanks for any help. Also, car is Vortech supercharged and have already soldered the timing controller wires at the kick panel. Thanks again.
Old Dec 21, 2015 | 06:01 AM
Slowcrash_101's Avatar
You mean the crank angle sensor?
That one is mounted on the cam chain case pointed at the crank by the crank pulley
Or the cam angle sensors?
The two sensors at the back of the valve cover.
Old Dec 21, 2015 | 07:45 AM
flanders's Avatar
TDC1 is on drivers side and TDC2 is passenger side, this is on a left hand drive car
Old Dec 21, 2015 | 11:21 AM
mhollifi's Avatar
Thanks, that is the info I was looking for.
unowned
Apr 11, 2021 08:19 AM
Sky1air
Mar 10, 2016 05:13 PM
Swiftoy
May 18, 2015 09:27 AM
DJ Maestro
Aug 22, 2012 06:11 PM
JLuda
Jun 13, 2007 07:28 PM
