Tein RA vs. Flex
Originally Posted by jlvtx1800,Jan 1 2005, 12:47 PM
So then why are the RA's more expensive? It sounds like the FLEX is a better deal
John
John
I mean, did you ever think you would have a system where you would be able to control damping from inside the car? Typically, your car has to have a prancing horse or bull on it to get those kinds of gadgets!
The new Cadillac CTS-V has an active suspension that works pretty well. The damping and rebound adjust accordingly in "competition" mode as does the steering.
I would want to see how the Tein EDFC works in the real world as normally something like an active suspension would need to be tuned for the particular car it's being used on.
Originally Posted by jchung,Jan 1 2005, 03:42 PM
if i remember correctly, the flex + edfc is a bit more expensive than the ra's.
Originally Posted by Fast Shadow,Jan 1 2005, 08:43 PM
But how well does it work? I've tried the active suspensions in Corvettes and I didn't like them. The plain old Z51 "sport" suspension was much better (and weighed a lot less). I'm pretty sure the Porsche 959 had an active suspension, but if it was anything like the rest of that car it was about 20 years ahead of its time and cost $4958549854.
I am trying to find the differences between just the suspensions though. There is about a $350 difference and I just can't figure out why. The RAs are a mono tube which is a better setup, but then you guys are giving several aspects of the FLEX which are better then the RA. There has to be (hopefully) something that sets the RA apart from the FLEX. Thanks so far for all the help.
John
There is a word of mouth that all Tein suspension are backbone jarring stiff. How true is this with the Flex? How soft is the lowest bump/rebound setting? Is it softer than the stock suspension with this setting?
Thanks for the feedback Clayman. I've got a set of Drummon Motor Sport coilover so I know what's a good system can do to the car's handling
.....and best of all the lowest setting is softer than stock and handles very well. I've heard that the lowest rebound/bump on the RA is still harsher than stock coilover though. Is this true?
I love the idea of hassle free adjustment with the flex system though. This flex system was not available when I got my DMS. I am interest in more feedback(s) on the lowest bump/rebound setting with the Flex system?
.....and best of all the lowest setting is softer than stock and handles very well. I've heard that the lowest rebound/bump on the RA is still harsher than stock coilover though. Is this true?I love the idea of hassle free adjustment with the flex system though. This flex system was not available when I got my DMS. I am interest in more feedback(s) on the lowest bump/rebound setting with the Flex system?
i don't think Tein RA's ride quality is that harsh.
i'm running 5 clicks from the hardest setting.
when i drive on the street, it feels just like my stock suspension.
If i go drive on the freeway, it's a different story.
i'm pretty happy with the suspension.
the car handles very good now.
however, i got the suspension installed, racing spec aligned and cornor weighted at one time. so i don't know if the tunning contributes a major portion on the improvement.
i only find one problem with the system.
it seems to me there is no fu*king way that i can fit my fingers under the gasline filling pipe to adjust the driver rear suspension.
can somebody please tell me how -------------------------------- ?!
The Flex is made of steel. The threads are Teflon coated not to prevent seizing from dirt, but as a layer of protection for rust (something the SS model doesn't have). The RA is a full aluminum damper, casing and brackets. It is considerably lighter (lift each one and you'll feel a dramatic difference in weight) and will not rust (so no need for teflon if the material itself is rust proof). Aluminum is more difficult to work with and the additional labor/cost required to manufacture it is reflected in the price. Also, a lighter damper results in less unsprung weight resulting in a quicker responding suspension setup to both steering and bumps. Less weight makes the shock itself work less since during bump, it's mostly the unsprung weight that will store energy in the spring and the shock will need to dissipate. The monotube vs. twintube design also factors into the cost, but most of the cost is due to the material of the damper and brackets. The Flex may be the best choice for needs, but the RA is a better shock. If you don't need or care about the features of the RA and feel the Flex's features are more suitable for your requirements, then the Flex would be a better choice.
The Flex (and even RA) aren't valved that aggressively. I feel BC RS's are valved more aggressively, and in some applications, JIC's are valved more aggressively than the Teins. But, I've never ridden with these shocks in an S, only on other cars.
John
