Temp Gauge Weirdness? Or...?
Old Mar 20, 2008 | 01:00 PM
Spankypoo's Avatar
Default Temp Gauge Weirdness? Or...?
Hey all --
For background, the car's a bone-stock 2004, with ~15k miles. It's never been modified in any way (besides the glovebox organizer ).
Within a few minutes of starting the car, the temp gauge climbs to eight bars. Yes, eight. And there it sits, and sits, and sits. I never figured it was a big deal, because the gauge still has miles to go, I've never gotten a warning light/beep, etc. I swear the thing used to sit a three bars and one day went to eight, but it could be my mind playing tricks on me.
Using a temp gun, the engine bay temps seem really low. I can still grab the radiator hose (it's about 145 degrees at its hottest point after idling for 8-10 minutes and being at eight bars), so I kind of doubt that the actual temp's really getting that high. The radiator's not blocked off, there's no front plate, the coolant level's fine, etc.
Any ideas other than a bum sensor? Anybody know where I should aim the temp gun to get a more useful reading to verify the actual water temp?
And being out of warranty, if it's a sensor is it a pretty straightforward install?
Thanks!
Old Mar 20, 2008 | 01:02 PM
CypherAZ's Avatar
I've been having the same problem, my dealership said it's "normal."
Old Mar 20, 2008 | 03:17 PM
Spankypoo's Avatar
Hmm. Thanks for the response. I wonder if they're just passing the buck, or if it is indeed normal.
So after a spirited drive, I stopped and checked the temps -- the radiator hose was a bit warmer, ~165. The valve cover was over 170.
Warmer, but still not terribly out of whack, at least from my perspective.
Anyone have any insights?
Old Mar 20, 2008 | 08:05 PM
geminimech's Avatar
I believe 8 bars for the ap2 "water temp" gauge is normal operating temperature. Someone can correct me if I am mistaken.
Old Mar 20, 2008 | 09:31 PM
Spec_Ops2087's Avatar
I thought the same thing...
Old Mar 21, 2008 | 08:08 AM
centralcoastbuc's Avatar
7 or 8 bars is normal for AP2s.
Old Mar 21, 2008 | 09:42 AM
Spankypoo's Avatar
Really? Tragedy averted, I guess.
I've found the numbers on AP1 temp gauges and what each bar represents; anybody have the specs for the AP2?
Old Mar 21, 2008 | 03:53 PM
geminimech's Avatar
Yea from what I understand "normal operating temperature" (8 bars) is anywhere between not warm enough and complete meltdown. 160-235 I believe?
Old Mar 21, 2008 | 05:25 PM
Spankypoo's Avatar
That's hilarious. And you'd think Honda would require more than three bars for VTEC engagement, if eight's such a wide range. Plus, I get the feeling that bars three, four, five, six and seven all represent about three degree windows, as once it gets past two it climbs up to eight really quickly.
I really wish Honda had stuck a numeric reading inside of the arc of bars. Oh well.
Thanks for all the help!
Old Mar 21, 2008 | 05:32 PM
INTJ's Avatar
This is not a precision guage, nor is it a precision sensor. You'll feel the overheating, its generally supposed to give just before vertical in the normal range.
