Temperature guage?
Old Jul 3, 2002 | 06:32 AM
RayN's Avatar
How many bars on your temperature gauge do you guys have when the temperature is almost or past 90 C (or any temp) without AC? With AC?
Old Jul 3, 2002 | 06:50 AM
marcucci's Avatar
With the stock cooling system you should always see 3 bars, period. If you ever see more you should pull over immediately and let the car idle with the heater on full heat/full blast.
Old Jul 3, 2002 | 07:54 AM
Gernby's Avatar
Former Sponsor
I think that the heat range of a single bar is pretty broad. I have the Mugen Thermostat / Thermoswitch / Radiator Cap, and I get up to 3 bars within 1 minute. I've taken temp measurements side by side with another stock S2000 at extended idle, and found that there was at least 20 degrees F difference, but both showed 3 bars.
Old Jul 3, 2002 | 10:27 AM
RayN's Avatar
I added a redline water weeter on my cooling system. It works really good on my previous turbo car.
Old Jul 3, 2002 | 12:50 PM
twohoos's Avatar
It's been shown (see for example http://hondas2000accessories.com/serv03.htm) that the 3rd bar first comes on when the coolant temp reaches about 120 deg F, and the 4th bar lights at about 220 F. So, there's a 100 degree range captured in that 3rd bar. Presumably Honda intended this to represent the full-scale normal/safe operating range for the car, so that you could check the temp Goldilocks-style (2 bars = too cold, 4 bars = too hot, 3 bars = just right!).
BTW, did you mean 90 F (e.g. ambient air temp)?
Old Jul 3, 2002 | 12:57 PM
Rick Hesel's Avatar
Former Sponsor
twhhoos is right.
I have a digital temperature gauge and it's usually at about 120 degress F when the stock gauge hits 3 bars. In normal conditions, the water temp ranges from about 160 to 185. When it gets higher, the fans cool it down to about 175. My digital gauge also records max temp during a run, and I've never seen that over about 210.
David41
Mar 6, 2014 04:50 PM
tekka01
Mar 15, 2011 01:05 PM
Boost76
Aug 6, 2010 07:43 PM
AlX Boi
Dec 29, 2009 08:33 AM
BBY2KS2K
Dec 22, 2002 11:32 PM
