Temperature and power discussion
Old Jul 19, 2001 | 05:53 PM
texan's Avatar
my 02 shiny newbie cents...
Products like Redline's Water Wetter are surfactants, chemicals which drastically lower the surface tension of water (much like soap will). They work to aid heat transfer by making the water to metal contact more intimate, thus allowing higher levels of heat to be wicked away from the block on a single pass through the system.
Running low amounts of anti-freeze (such as the 15/75 mix mentioned earlier) is generally not a good idea, at least for long term reliability and engine health. Water is lightly corrosive to most metals, over time the lack of corrosion inhibitors present in anti-freeze will allow the water to take it's toll on the engine and cooling system. Water wetter will offset this some with it's own corrosion inhibitors, but there have been discussions before about how effective Redline's additive really is in this regard (possibly a better surfactant would be Neo's Keep Cool... http://www.neosyntheticoil.com/keepcool.htm).
Increasing system pressure not only has the obvious benefit of higher heat transfer levels for a single pas through, the higher boiling temps also lower the possibility of cylinder hot spotting due to vaporization issues in water jackets (where the extreme heat of a single point can cause the contacting water to flash boil and create an air pocket preventing the spot from being cooled). Decreasing thermostat activation temp has long been shown to help with engine cooling too, and yes both can certainly go hand in hand to provide great increases in cooling capacity from the same basic system.
One of the most interesting developments in coolant technology, IMO, is waterless coolants with tailor made properties. Much like synthetic oils, logic dictates that one could engineer a coolant with better properties than mere water/anti-freeze mixes, and from the little bit of information I have found on Evans NPG, this seems to be true. Check out http://www.evanscooling.com/main25.htm for more info.
Old Jul 19, 2001 | 07:19 PM
pfb's Avatar
pfb
Thanks newbie texan! Good info... and welcome!
Old Jul 19, 2001 | 07:20 PM
pfb's Avatar
pfb
So we've discussed anti-freezes & thermostats...
Has anybody taken actual temperature measurements to determine what 3 bars really means?
Old Jul 19, 2001 | 07:23 PM
shingles's Avatar
I know three bar starts at about 165*-167*F according to the ECU. It's upper limits I do not know.
-shing
Old Jul 19, 2001 | 08:34 PM
Tanqueray's Avatar
[QUOTE]Originally posted by texan
[B]
Old Jul 19, 2001 | 09:03 PM
texan's Avatar
Conventional wisdom suggests a 50/50 mix is optimal, where reliability, lubrication, corosion resistance and what-not is well balanced. You also have to remember that water is a terrible lubricant, you will likely burn up your water pump bearing pretty quickly with a 15/85 mix.
Old Jul 19, 2001 | 10:32 PM
mingster's Avatar
[QUOTE]Originally posted by Tanqueray
[B]I am using a high-pressure radiator cap for a different reason.
Old Jul 19, 2001 | 10:40 PM
Prolene's Avatar
Mingster, do you have any of the Spoon thermostats on hand?
Old Jul 20, 2001 | 03:52 AM
cdelena's Avatar
What do you recommend as a minimum level of antifreeze?
I think most of the write-ups I have seen suggest no less than 30% for long term use of Ethylene Glycol.
Of course the newer Propylene Glycol antifreezes are sometimes used straight without water. Great freeze/boil numbers but I don
Old Jul 20, 2001 | 09:36 AM
josh3io's Avatar
[QUOTE]Originally posted by cdelena
[B]
