Tenioner pulley indicator position
I'm under the assumption that the belt tightens as it heats up? I could be completely wrong here, but is proper belt tension taken when the car is up to operating temp in the bay? Or is it checked with the car off and cold? I can't see your belts stretching out of spec that quickly.....Unless you see weird stuff going on like the belt not tracking properly or the tensioner moving back and forth I wouldn't worry about it. Especially with new OEM belts......damn. I bought one to do mine when I get around to it and I hard time forking out the cash for just a damn belt.....
for your belt issue, inspect each pully see if there is anything off, otherwise I would just drive her and keep a spare belt in the trunk.
The belt wear indicator marks are not accurate, only a guide. Do not let them sway you.
You can remove the belt, loosen the two tensioner bolts, and re-clock the unit slightly for better accuracy.
To save your rectifier and prevent a flickering dashboard, always try to charge a dead battery with a wall charger.
If your battery is dead or very low, for some reason, rather than perform a jump start and drive it (the alternator will provide for the running car and also charge the battery) it is better to charge the battery with a charger (or replace the battery with a good one). This prevents destroying the rectifier from all the current the alternator would provide charging the battery with the car in operation.
This may be a little inconvenient but so is replacing the rectifier.
so you're saying jump starting is bad for the alternator. i don't doubt the accuracy of that, since it's simply true or not true.
but what's interesting is that my rectifier went bad from never having jump started it. the battery was replaced once at a honda dealership before the original battery even exhibited any problems.
comparatively, with a new rectifier, i had jump started a dead battery three or four times. the rectifier is still holding up longer after the multiple jump starts, compared to the original rectifier that went bad with zero jumpstarts.
strange.
strange.
But why would Honda provide these indicator marks if it's not accurate and so then how does one know what range they should be in?
