Test Pipe Install
Old Apr 11, 2006 | 03:29 PM
JSWhaler's Avatar
Default Test Pipe Install
Ok, so I've installed my test pipe, but I need to see what you guys think. The pictures show the install, but the front part (connected to header) doesn't seem to fit flush. While the car is running no exhaust comes out, haven't hit vtec yet. This is the Berk test pipe. You can see that the rear matches beautifully. I'm using the oem front springy bolts and rears they provided. My OEM rear bolts are too rusted to be used again. Should I change this? Worry about it? The white part sticking out is fluch between both pipes.
Old Apr 11, 2006 | 03:38 PM
WalkingDrunken's Avatar
Yes you installed it correctly. It doesn't sit flush on mine either I think it's the gasket that does that. But as long as you have no leaks you should be all set. Enjoy
Old Apr 11, 2006 | 03:40 PM
marshallhunting's Avatar
Honda uses that ball joint thingy instead of a flex bellow, it allows for movement vibration. the install looks fine to me... you could even back the nuts off (alittle) so the springs are not maxed out.
Old Apr 11, 2006 | 03:43 PM
JSWhaler's Avatar
thanks this makes me feel a lot better
Old Apr 11, 2006 | 04:15 PM
Slows2k's Avatar
It's normal. The OEM convertor fits the same way.
Old Apr 11, 2006 | 06:29 PM
gomarlins3's Avatar
I agree with the above.
Old Apr 11, 2006 | 08:00 PM
S2kracka's Avatar
Leave some play in the springs so they can do their job by flexing.
Old Apr 12, 2006 | 04:28 AM
vtec9's Avatar
is your exhaust otherwise stock? How does it sound? I just ordered a berk testpipe yesterday!
Old Apr 12, 2006 | 05:28 AM
JSWhaler's Avatar
yes the rest of the exhaust is stock and it sounds nice.
Old Apr 12, 2006 | 10:44 AM
Reborn56's Avatar
hey JSWhaler did you have a problem in gettin the 3 rusted bolts out?
what did you use to take it off
i used wd40 and a closed end wrench and damn thing didnt wanna come off
what did you do?
