Test Pipe Install
Old Mar 2, 2008 | 08:44 PM
D1sclaimer's Avatar
Default Test Pipe Install
Im thinking nows a good time to throw my inividia test pipe on since its nicer out. I have a few questions.
1. My brother who knows a little about cars says that jacking the s2000 and keeping it up at the jack points is bad on the chassis. I was gonna just jack up the rear at both the rear points. Can you confirm this cause I think its bs.
2. Did you have to use a breaker bar to get the bolts off?
3. Will an electric 240lb torque impact wrench work or will I need to buy a better pneumatic one(I've got a compressor)?
Thanks, I've been itching to get this done.
Old Mar 2, 2008 | 08:56 PM
babowc's Avatar
Breaker bar + wrenches = done.
I don't see how you're going to lift the rear points and get to the test pipe.
You should be able to lift it by the tranny no problem.
If you want to lift it from the back so much, you can lift it on the diff.
You probably don't even have to "lift" the car..
Just get some ramps and drive up. It'll give you plenty clearance to swap out for the test pipe!
Old Mar 2, 2008 | 08:58 PM
CourageOO7's Avatar
I can't even count the number of times I've jacked up my car. This isn't a 1970 Chevelle with a chassis as soft as a noodle. This chassis is quite rigid (especially for a convertible) and there's nothing wrong with jacking it up for a few minutes to work on it.
Old Mar 2, 2008 | 08:59 PM
babowc's Avatar
WINNAR.
Old Mar 2, 2008 | 09:01 PM
D1sclaimer's Avatar
Thanks for the reply!!
I don't have any ramps and don't know anyone with them. Im on kinda a tight budget at the moment so I've got to work with what I have.
I have no clue how to lift from the tranny or differential. Would this be in the service manual on how to do this cause I've got it?
Old Mar 2, 2008 | 09:07 PM
babowc's Avatar
Na.. just slide your car on some 2x4 and stick your jack underneath the tranny and lift it up.
Then support the car with stands.
When you're lowering the car, don't forget to stack some 2x4 so you don't get stuck in the middle of lowering the car back down.
Old Mar 2, 2008 | 09:12 PM
neeman77's Avatar
why can't he just jack up on the front JACK POINTS and then put jack stands under the control arms? Thats what I would do...
D1sclaimer's Avatar
Thanks for the help.
Old Mar 2, 2008 | 09:14 PM
AP_ONE's Avatar
Stick a jack under the diff, jack the car up using the diff. then place 2 jack stands under the car. side rear where rear tires go, youll know what i mean, a few bolts and your done. A elec impact will do fine or a long breaker bar
enjoy and hope for no cel
Old Mar 2, 2008 | 10:38 PM
D1sclaimer's Avatar
After thinking about, I have some spare wood. I think I'll just go ahead and make some ramps out of it. Whats the best height to make them to be able to do exhaust work and oil changes and such.
absolute_jdm
May 23, 2008 11:53 PM
JSWhaler
Apr 6, 2006 05:35 AM
bborzell
Nov 19, 2005 11:10 AM
Emil St-Hilaire
Aug 28, 2005 09:46 PM
