Test Pipe Smoke
Old Sep 12, 2010 | 05:01 PM
ahrmike's Avatar
Default Test Pipe Smoke
How many of you with a test pipe notice/see this?
I've been getting a lot of puffs of smoke recently (not at once, just a big puff of smoke...but its been happening more regularly - or im noticing it more regularly) and I wanted to know the size/color/frequency/oil consumption/ambient conditions of when it occurs for YOU guys.
Size: Big enough to see at night when other cars are behind me
color: whiteish/grayish (?) not too sure since all I see is the lights being covered
Frequency: I notice it once a week, so perhaps once or twice a day?
oil consumption: Normal consumption for AP1, maybe 1 qt per 2K miles
ambient condition: I only notice it at NIGHT and usually when its HUMID.
smell: I can also SMELL it right before I see it, if my windows are down/AC is off. I have an exhaust leak from the TP section (buying a new donut gasket now) so I think thats why I can smell it, it smells like oil burning.
I'm talking about big puffs of smoke, as in I can see it from my right, left and rearview mirror!
I thought it'd be helpful for others as well, after they install a test pipe so they dont freak out like I did/am doing.
I notice it happens only when the car is NOT warmed fully, that is: 3 bars but not at hottest temp - I have a feeling this might be the rings not fully expanding?
edit
others with the same symptoms:
2000 AP1 (happens acceleration then slow to stop, smoke at idle)
2002 AP1 (every now and then)
2005 AP2 (only during WOT)
2002 Ap1 (acceleration->stop)
Old Sep 12, 2010 | 05:03 PM
240toS2k's Avatar
I've never had puffs of smoke like you described after I put in my test pipe... are you sure that's normal?
Old Sep 12, 2010 | 08:17 PM
wisdom's Avatar
Its only happened to me a few times, driving in traffic, did a 4k acceleration and then i had to put it in neutral to stop and right back into gear. It was a poof of greyish smoke. I can always smell my test pipe.
What oil are you using?
Old Sep 12, 2010 | 08:21 PM
JDMQuip's Avatar
A puff of smoke here and there is somewhat normal for running a TP. However from what you described it sounds like blow-by from maybe worn out rings?
No way to tell unless you give us more info. i.e...mods, mileage on the car, etc...
Old Sep 12, 2010 | 08:34 PM
Presto123's Avatar
I get a puff of white smoke every now and then also. I've been told black smoke exits my mufflers at high rpm shifts also.
Old Sep 12, 2010 | 09:13 PM
ahrmike's Avatar
240, are you certain that you're not getting it? I am almost 100% sure that its a byproduct of the TP. I'll get some compression numbers but the car itself runs great.
if you do a search for "smoke" in s2ki theres a bunch of those threads. if I had worn out rings, wouldn't the smoke be more noticeable all the time + at high RPMS?
I'm getting this smoke as I take off from a light, sporadically..
Presto, I think the black smoke is very common for all s2000 since they run rich/leave carbon deposits. On a recent cruise, every s2000 in front of me that was shifting was blowing out black carbon smoke.
wisdom, I'm using Mobil1 EP (supposed to be a lot better than M1 standard)
Old Sep 13, 2010 | 02:53 AM
240toS2k's Avatar
I don't think I'm getting any puffs of smoke from my TP, maybe it's not happening often enough for me to even notice. I do have the awful TP smell though, but that's to be expected.
Old Sep 13, 2010 | 04:32 AM
hypforlife32's Avatar
Is it only happen in vtec or just all of the time?
Old Sep 13, 2010 | 08:27 AM
exalto's Avatar
As I'm about to fit a test pipe, I'm curious about the accompanying smell that people often refer to.
Can anyone describe this?
Old Sep 13, 2010 | 08:33 AM
240toS2k's Avatar
Smells like you're running rich, except 100x more potent.
